[petsc-dev] HDF5 + p4est regression
Mark Adams mfadams at lbl.gov
Wed Dec 20 07:52:03 CST 2023
Cool, it's not in main is it?
On Wed, Dec 20, 2023 at 8:51 AM Matthew Knepley <knepley at gmail.com> wrote:
> That is the problem Berend is asking about. Toby and I have to fix it.
>   Matt
> On Wed, Dec 20, 2023 at 7:49 AM Mark Adams <mfadams at lbl.gov> wrote:
>> I seem to have a regression with writing HDF5 meshes with DMForest.
>> I going to try bisect but wanted to see if anyone has any ideas,
>> Thanks,
>> Mark
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Invalid argument
>> [0]PETSC ERROR: Unknown discretization type for field 0
>> [0]PETSC ERROR: WARNING! There are unused option(s) set! Could be the
>> program crashed before usage or a spelling mistake, etc!
>> [0]PETSC ERROR:   Option left: name:-ex30_vec_view value:
>> hdf5:sol_e.h5::append source: command line
>> [0]PETSC ERROR:   Option left: name:-options_left (no value) source:
>> command line
>> [0]PETSC ERROR:   Option left: name:-snes_converged_reason (no value)
>> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
>> [0]PETSC ERROR: Petsc Development GIT revision: v3.20.2-363-g9617a9bff32
>>  GIT Date: 2023-12-19 16:12:36 +0000
>> [0]PETSC ERROR: ./ex30 on a arch-macosx-gnu-O named MarksMac-302.local by
>> markadams Wed Dec 20 07:39:06 2023
>> [0]PETSC ERROR: Configure options CFLAGS="-g -Wno-deprecated-declarations
>> " CXXFLAGS="-g -Wno-deprecated-declarations " COPTFLAGS=-O CXXOPTFLAGS=-O
>> --with-cc=/usr/local/opt/llvm/bin/clang
>> --with-cxx=/usr/local/opt/llvm/bin/clang++ --download-mpich
>> --with-64-bit-indices=1 --download-parmetis=1 --download-metis=1
>> --download-zoltan=1 --download-hypre=1 --download-triangle=1
>> --download-kokkos=1 --download-kokkos-kernels=1 --download-p4est=1
>> --with-zlib-dir=/usr/local/opt/zlib --with-debugging=0 --download-hdf5=1
>> PETSC_DIR=/Users/markadams/Codes/petsc2 PETSC_ARCH=arch-macosx-gnu-O
>> [0]PETSC ERROR: #1 DMCreateLocalSection_Plex() at
>> /Users/markadams/Codes/petsc2/src/dm/impls/plex/plexsection.c:476
>> [0]PETSC ERROR: #2 DMGetLocalSection() at
>> /Users/markadams/Codes/petsc2/src/dm/interface/dm.c:4293
>> [0]PETSC ERROR: #3 DMCreateDefaultConstraints_Plex() at
>> /Users/markadams/Codes/petsc2/src/dm/impls/plex/plex.c:10263
>> [0]PETSC ERROR: #4 DMGetDefaultConstraints() at
>> /Users/markadams/Codes/petsc2/src/dm/interface/dm.c:4389
>> [0]PETSC ERROR: #5 DMPlexComputeAnchorMatrix_Tree_FromReference() at
>> /Users/markadams/Codes/petsc2/src/dm/impls/plex/plextree.c:1561
>> [0]PETSC ERROR: #6 DMCreateDefaultConstraints_Plex() at
>> /Users/markadams/Codes/petsc2/src/dm/impls/plex/plex.c:10267
>> [0]PETSC ERROR: #7 DMGetDefaultConstraints() at
>> [0]PETSC ERROR: #8 DMLocalToGlobalHook_Constraints() at
>> /Users/markadams/Codes/petsc2/src/dm/interface/dm.c:2941
>> [0]PETSC ERROR: #9 DMLocalToGlobalBegin() at
>> /Users/markadams/Codes/petsc2/src/dm/interface/dm.c:3042
>> [0]PETSC ERROR: #10 DMGetCoordinates() at
>> /Users/markadams/Codes/petsc2/src/dm/interface/dmcoordinates.c:429
>> [0]PETSC ERROR: #11 DMPlexCoordinatesView_HDF5_Legacy_Private() at
>> /Users/markadams/Codes/petsc2/src/dm/impls/plex/plexhdf5.c:1007
>> [0]PETSC ERROR: #12 DMPlexCoordinatesView_HDF5_Internal() at
>> /Users/markadams/Codes/petsc2/src/dm/impls/plex/plexhdf5.c:1044
>> [0]PETSC ERROR: #13 DMPlexView_HDF5_Internal() at
>> /Users/markadams/Codes/petsc2/src/dm/impls/plex/plexhdf5.c:1300
>> [0]PETSC ERROR: #14 DMView_Plex() at
>> /Users/markadams/Codes/petsc2/src/dm/impls/plex/plex.c:1924
>> [0]PETSC ERROR: #15 DMView() at
>> /Users/markadams/Codes/petsc2/src/dm/interface/dm.c:989
>> [0]PETSC ERROR: #16 PetscObjectView() at
>> /Users/markadams/Codes/petsc2/src/sys/objects/destroy.c:78
>> [0]PETSC ERROR: #17 PetscObjectViewFromOptions() at
>> /Users/markadams/Codes/petsc2/src/sys/objects/destroy.c:130
>> [0]PETSC ERROR: #18 DMViewFromOptions() at
>> /Users/markadams/Codes/petsc2/src/dm/interface/dm.c:933
>> [0]PETSC ERROR: #19 go() at ex30.c:238
>> [0]PETSC ERROR: #20 main() at ex30.c:494
>> [0]PETSC ERROR: PETSc Option Table entries:
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20231220/8e461124/attachment-0001.html>
