[petsc-dev] HDF5 + p4est regression
Wed Dec 20 07:50:54 CST 2023
That is the problem Berend is asking about. Toby and I have to fix it.
  Matt
On Wed, Dec 20, 2023 at 7:49 AM Mark Adams <mfadams at lbl.gov> wrote:
> I seem to have a regression with writing HDF5 meshes with DMForest.
> I going to try bisect but wanted to see if anyone has any ideas,
> Thanks,
> Mark
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Invalid argument
> [0]PETSC ERROR: Unknown discretization type for field 0
> [0]PETSC ERROR: WARNING! There are unused option(s) set! Could be the
> program crashed before usage or a spelling mistake, etc!
> [0]PETSC ERROR:   Option left: name:-ex30_vec_view value:
> hdf5:sol_e.h5::append source: command line
> [0]PETSC ERROR:   Option left: name:-options_left (no value) source:
> command line
> [0]PETSC ERROR:   Option left: name:-snes_converged_reason (no value)
> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
> [0]PETSC ERROR: Petsc Development GIT revision: v3.20.2-363-g9617a9bff32
>  GIT Date: 2023-12-19 16:12:36 +0000
> [0]PETSC ERROR: ./ex30 on a arch-macosx-gnu-O named MarksMac-302.local by
> markadams Wed Dec 20 07:39:06 2023
> [0]PETSC ERROR: Configure options CFLAGS="-g -Wno-deprecated-declarations
> " CXXFLAGS="-g -Wno-deprecated-declarations " COPTFLAGS=-O CXXOPTFLAGS=-O
> --with-cc=/usr/local/opt/llvm/bin/clang
> --with-cxx=/usr/local/opt/llvm/bin/clang++ --download-mpich
> --with-64-bit-indices=1 --download-parmetis=1 --download-metis=1
> --download-zoltan=1 --download-hypre=1 --download-triangle=1
> --download-kokkos=1 --download-kokkos-kernels=1 --download-p4est=1
> --with-zlib-dir=/usr/local/opt/zlib --with-debugging=0 --download-hdf5=1
> PETSC_DIR=/Users/markadams/Codes/petsc2 PETSC_ARCH=arch-macosx-gnu-O
> [0]PETSC ERROR: #1 DMCreateLocalSection_Plex() at
> /Users/markadams/Codes/petsc2/src/dm/impls/plex/plexsection.c:476
> [0]PETSC ERROR: #2 DMGetLocalSection() at
> /Users/markadams/Codes/petsc2/src/dm/interface/dm.c:4293
> [0]PETSC ERROR: #3 DMCreateDefaultConstraints_Plex() at
> /Users/markadams/Codes/petsc2/src/dm/impls/plex/plex.c:10263
> [0]PETSC ERROR: #4 DMGetDefaultConstraints() at
> /Users/markadams/Codes/petsc2/src/dm/interface/dm.c:4389
> [0]PETSC ERROR: #5 DMPlexComputeAnchorMatrix_Tree_FromReference() at
> /Users/markadams/Codes/petsc2/src/dm/impls/plex/plextree.c:1561
> [0]PETSC ERROR: #6 DMCreateDefaultConstraints_Plex() at
> /Users/markadams/Codes/petsc2/src/dm/impls/plex/plex.c:10267
> [0]PETSC ERROR: #7 DMGetDefaultConstraints() at
> [0]PETSC ERROR: #8 DMLocalToGlobalHook_Constraints() at
> /Users/markadams/Codes/petsc2/src/dm/interface/dm.c:2941
> [0]PETSC ERROR: #9 DMLocalToGlobalBegin() at
> /Users/markadams/Codes/petsc2/src/dm/interface/dm.c:3042
> [0]PETSC ERROR: #10 DMGetCoordinates() at
> /Users/markadams/Codes/petsc2/src/dm/interface/dmcoordinates.c:429
> [0]PETSC ERROR: #11 DMPlexCoordinatesView_HDF5_Legacy_Private() at
> /Users/markadams/Codes/petsc2/src/dm/impls/plex/plexhdf5.c:1007
> [0]PETSC ERROR: #12 DMPlexCoordinatesView_HDF5_Internal() at
> /Users/markadams/Codes/petsc2/src/dm/impls/plex/plexhdf5.c:1044
> [0]PETSC ERROR: #13 DMPlexView_HDF5_Internal() at
> /Users/markadams/Codes/petsc2/src/dm/impls/plex/plexhdf5.c:1300
> [0]PETSC ERROR: #14 DMView_Plex() at
> /Users/markadams/Codes/petsc2/src/dm/impls/plex/plex.c:1924
> [0]PETSC ERROR: #15 DMView() at
> /Users/markadams/Codes/petsc2/src/dm/interface/dm.c:989
> [0]PETSC ERROR: #16 PetscObjectView() at
> /Users/markadams/Codes/petsc2/src/sys/objects/destroy.c:78
> [0]PETSC ERROR: #17 PetscObjectViewFromOptions() at
> /Users/markadams/Codes/petsc2/src/sys/objects/destroy.c:130
> [0]PETSC ERROR: #18 DMViewFromOptions() at
> /Users/markadams/Codes/petsc2/src/dm/interface/dm.c:933
> [0]PETSC ERROR: #19 go() at ex30.c:238
> [0]PETSC ERROR: #20 main() at ex30.c:494
> [0]PETSC ERROR: PETSc Option Table entries:
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20231220/5418ef9c/attachment.html>
