[petsc-dev] Branches with additional features
Pierre Jolivet Pierre.Jolivet at enseeiht.fr
Mon May 22 01:11:30 CDT 2017
On Sun, 21 May 2017 17:10:30 -0500, Barry Smith wrote:
>> On May 21, 2017, at 3:17 PM, Pierre Jolivet
>> <pierre.jolivet at enseeiht.fr> wrote:
>> Hello,
>> I’m wondering if any branch has one or more of the following
>> features (or if this is in the pipeline somehow):
>> 1) MKL PARDISO support for MPIAIJ
>> 2) MKL PARDISO support for MPIBAIJ using iparm(37)
>> https://software.intel.com/en-us/mkl-developer-reference-fortran-pardiso-iparm-parameter#IPARM37
>   From:
> https://software.intel.com/en-us/mkl-developer-reference-fortran-sparse-blas-bsr-matrix-storage-format#GUID-9BD4DADE-6059-4042-BC2A-F41048A47953
> values
> A real array that contains the elements of the non-zero blocks of a
> sparse matrix. The elements are stored block by block in row-major
> order. A non-zero block is the block that contains at least one
> non-zero element. All elements of non-zero blocks are stored, even if
> some of them is equal to zero. Within each non-zero block the
> elements
> are stored in column major order in the case of the one-based
> indexing, and in row major order in the case of the zero-based
> indexing.
> columns
> Element i of the integer array columns is the number of the column in
> the block matrix that contains the i-th non-zero block.
> rowIndex
> Element j of this integer array gives the index of the element in the
> columns array that is first non-zero block in a row j of the block
> matrix.
> Unfortunately PETSc always stores "Within each non-zero block the
> elements are stored in column major order" even though this it uses
> zero based indexing. This means the matrix storage would need to be
> monkeyed with before using MKL PARDISO. In order to reduce memory
> usage and excess copying I would make copies of the columns and
> rowIndex integers and shift them to one based indices and then you
> can
> pass these to MKL Pardiso using the BCSR format; this is
> straightforward for SeqBAIJ matrices. Like Matt said I don't know if
> MKL PARDISO is appropriate for MPI matrices.
OK, I see. That is true that MKL storage layout is somehow confusing as
it depends on the numbering used.
Concerning PARDISO, I got confused because Google only redirects to
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MATSOLVERMKL_PARDISO.html#MATSOLVERMKL_PARDISO
There is no such page as
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MATSOLVERMKL_CPARDISO.html#MATSOLVERMKL_CPARDISO
But MKL_CPARDISO is indeed defined there
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatSolverPackage.html#MatSolverPackage,
thanks for the pointer Stefano.
>> 3) MatMatMult_MPIBAIJ_MPIDense
>    We don't have any of the MatMatMult_XXXBAIJ_MPIDense() multiple
> routines but they should be pretty easy to add, just copy the
> corresponding AIJ routines and make the appropriate adjustments to
> take into account the blocks.
Yes, I've started copying most of the MatMatMult_XXXAIJ_XXXDense()
routines. I was just wondering if someone already did that or tried to
use specialized libraries like libxsmm, but it looks like I'll have to
do it myself.
Thanks for your inputs!
>> Thanks in advance,
>> Pierre
