[petsc-dev] Branches with additional features
Sun May 21 17:10:30 CDT 2017
> On May 21, 2017, at 3:17 PM, Pierre Jolivet <pierre.jolivet at enseeiht.fr> wrote:
> Hello,
> I’m wondering if any branch has one or more of the following features (or if this is in the pipeline somehow):
> 1) MKL PARDISO support for MPIAIJ
> 2) MKL PARDISO support for MPIBAIJ using iparm(37) https://software.intel.com/en-us/mkl-developer-reference-fortran-pardiso-iparm-parameter#IPARM37
   https://software.intel.com/en-us/mkl-developer-reference-fortran-sparse-blas-bsr-matrix-storage-format#GUID-9BD4DADE-6059-4042-BC2A-F41048A47953
values
A real array that contains the elements of the non-zero blocks of a sparse matrix. The elements are stored block by block in row-major order. A non-zero block is the block that contains at least one non-zero element. All elements of non-zero blocks are stored, even if some of them is equal to zero. Within each non-zero block the elements are stored in column major order in the case of the one-based indexing, and in row major order in the case of the zero-based indexing.
columns
Element i of the integer array columns is the number of the column in the block matrix that contains the i-th non-zero block.
rowIndex
Element j of this integer array gives the index of the element in the columns array that is first non-zero block in a row j of the block matrix.
Unfortunately PETSc always stores "Within each non-zero block the elements are stored in column major order" even though this it uses zero based indexing. This means the matrix storage would need to be monkeyed with before using MKL PARDISO. In order to reduce memory usage and excess copying I would make copies of the columns and rowIndex integers and shift them to one based indices and then you can pass these to MKL Pardiso using the BCSR format; this is straightforward for SeqBAIJ matrices. Like Matt said I don't know if MKL PARDISO is appropriate for MPI matrices.
> 3) MatMatMult_MPIBAIJ_MPIDense
   We don't have any of the MatMatMult_XXXBAIJ_MPIDense() multiple routines but they should be pretty easy to add, just copy the corresponding AIJ routines and make the appropriate adjustments to take into account the blocks.
> Thanks in advance,
> Pierre
