[petsc-dev] PETSC_DIR and PETSC_ARCH: used to distinguish between multiple applications ?
Jed Brown jed at jedbrown.org
Tue May 2 00:22:17 CDT 2017
Kevin Buckley <kevin.buckley.ecs.vuw.ac.nz at gmail.com> writes:
> On 24 April 2017 at 14:11, Matthew Knepley <knepley at gmail.com> wrote:
>>> The original package has a requirement for
>>>   --with-clanguage=cxx
>> Also, this is almost never needed. Are you sure the package needs it, or
>> just uses it due to history.
> Apologies, was away for a while.
> At the time I was building PISM, I believe that was a requirement,
That hasn't been a suggestion in the PISM distribution since 2009, as
far as I know (and checking the Git history).
> yes and so I continued building with it for later PETSc and PISM
> updates.
> Given your assertion, I should probably check that.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170501/78ed3f2c/attachment.sig>
