[petsc-dev] PETSC_DIR and PETSC_ARCH: used to distinguish between multiple applications ?
Kevin Buckley kevin.buckley.ecs.vuw.ac.nz at gmail.com
Tue May 2 00:15:59 CDT 2017
On 24 April 2017 at 14:11, Matthew Knepley <knepley at gmail.com> wrote:
>> The original package has a requirement for
>>   --with-clanguage=cxx
> Also, this is almost never needed. Are you sure the package needs it, or
> just uses it due to history.
Apologies, was away for a while.
At the time I was building PISM, I believe that was a requirement, yes
and so I continued building with it for later PETSc and PISM updates.
Given your assertion, I should probably check that.
