[petsc-dev] PETSC_DIR and PETSC_ARCH: used to distinguish between multiple applications ?
Kevin Buckley kevin.buckley.ecs.vuw.ac.nz at gmail.com
Tue May 2 00:31:03 CDT 2017
On 2 May 2017 at 17:22, Jed Brown <jed at jedbrown.org> wrote:
>> At the time I was building PISM, I believe that was a requirement,
> That hasn't been a suggestion in the PISM distribution since 2009, as
> far as I know (and checking the Git history).
Just checked,
my notes indicate that my first PISM build was in Aug 2009 so/but it's
possible I saw some docs that pre-dated the removal of that suggestion.
My original build flags also continued to work which why I have probably
never bothered to change things.
I will for the next build though, cheers
Kevin
