[petsc-dev] [petsc-maint] problems compiling petsc on MAC
Mon May 1 20:34:35 CDT 2017
pushed to master..
Satish
On Mon, 1 May 2017, Barry Smith wrote:
>    Ok, take them out of the C side also.
> > On May 1, 2017, at 6:39 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > On Mon, 1 May 2017, Jose E. Roman wrote:
> >>> El 1 may 2017, a las 22:27, Barry Smith <bsmith at mcs.anl.gov> escribió:
> >>> Is there are reason to have the same symbol in both library (note they come from the fortran versions)
> >>> $ nm -o arch-uni-f2cblaslapack/lib/libf2cblas.a | grep xerbla | grep " T "
> >>> arch-uni-f2cblaslapack/lib/libf2cblas.a:xerbla_array.o: 0000000000000000 T _xerbla_array_
> >>> arch-uni-f2cblaslapack/lib/libf2cblas.a:xerbla.o: 0000000000000000 T _xerbla_
> >>> ~/Src/petsc (next=) arch-basic
> >>> $ nm -o arch-uni-f2cblaslapack/lib/libf2clapack.a | grep xerbla | grep " T "
> >>> arch-uni-f2cblaslapack/lib/libf2clapack.a:xerbla_array.o: 0000000000000000 T _xerbla_array_
> >>> arch-uni-f2cblaslapack/lib/libf2clapack.a:xerbla.o: 0000000000000000 T _xerbla_
> >>> Should we remove them?
> >> I think it can be removed from libf2clapack.a. Not sure if that will have a side effect.
> > For some reason we removed the duplicate on the fortran side.
> > https://bitbucket.org/petsc/pkg-fblaslapack/commits/6bad5f72bf8aafb325d64402ab8f52b1d9b73cc9
> > Satish
