[petsc-dev] Using multiple mallocs with PETSc
Mon Mar 13 22:09:13 CDT 2017
> On Mar 13, 2017, at 9:37 PM, Jeff Hammond <jeff.science at gmail.com> wrote:
> OpenMP did not prevent OpenCL, C11, C++11 or Fortran 2008 from introducing parallelism. Not sure if your comment was meant to be serious, but it appears unfounded nonetheless.
  Ahh, but note that all of the "introduced parallelisms" by these "standards" sucked so Jed may have a valid point.
> Jeff
> On Sun, Mar 12, 2017 at 11:16 AM Jed Brown <jed at jedbrown.org> wrote:
> Implementation-defined, but it's exactly the same as malloc, which also doesn't promise unfaulted pages. This is one reason some of us keep saying that OpenMP sucks. It's a shitty standard that obstructs better standards from being created.
> On March 12, 2017 11:19:49 AM MDT, Jeff Hammond <jeff.science at gmail.com> wrote:
> On Sat, Mar 11, 2017 at 9:00 AM Jed Brown <jed at jedbrown.org> wrote:
> Jeff Hammond <jeff.science at gmail.com> writes:
> > I agree 100% that multithreaded codes that fault pages from the main thread in a NUMA environment are doing something wrong ;-)
> > Does calloc *guarantee* pages are not mapped? If I calloc(8), do I get the zero page or part of the arena that's already mapped that is zeroed by the heap manager?
> Is your argument that calloc() should never be used in multi-threaded code?
> I never use it for code that I want to behave well in a NUMA environment.
> If the allocation is larger than MMAP_THRESHOLD (128 KiB by default for
> glibc) then it calls mmap.  This obviously leaves an intermediate size
> that could be poorly mapped (assuming 4 KiB pages), but it's also so
> small that it easily fits in cache.
> Is this behavior standardized or merely implementation-defined? I'm not interested in writing code that assumes Linux/glibc.
> Jeff
> Jeff Hammond
> http://jeffhammond.github.io/
> Jeff Hammond
