[petsc-dev] Using multiple mallocs with PETSc
Jed Brown jed at jedbrown.org
Mon Mar 13 22:08:39 CDT 2017
Jeff Hammond <jeff.science at gmail.com> writes:
> OpenMP did not prevent OpenCL,
This programming model isn't really intended for architectures with
persistent caches.
> C11, C++11
These are basically pthreads, which predates OpenMP.
> or Fortran 2008
A different language and doesn't play well with others.
> from introducing parallelism. Not sure if your comment was meant to be
> serious,
Partially.  It was just enough to give the appearance of a solution
while not really being a solution.
> but it appears unfounded nonetheless.
> Jeff
> On Sun, Mar 12, 2017 at 11:16 AM Jed Brown <jed at jedbrown.org> wrote:
>> Implementation-defined, but it's exactly the same as malloc, which also
>> doesn't promise unfaulted pages. This is one reason some of us keep saying
>> that OpenMP sucks. It's a shitty standard that obstructs better standards
>> from being created.
>> On March 12, 2017 11:19:49 AM MDT, Jeff Hammond <jeff.science at gmail.com>
>> wrote:
>> > I agree 100% that multithreaded codes that fault pages from the main
>> thread in a NUMA environment are doing something wrong ;-)
>> > Does calloc *guarantee* pages are not mapped? If I calloc(8), do I get
>> the zero page or part of the arena that's already mapped that is zeroed by
>> the heap manager?
>> Is your argument that calloc() should never be used in multi-threaded code?
>> I never use it for code that I want to behave well in a NUMA environment.
>> If the allocation is larger than MMAP_THRESHOLD (128 KiB by default for
>> glibc) then it calls mmap.  This obviously leaves an intermediate size
>> that could be poorly mapped (assuming 4 KiB pages), but it's also so
>> small that it easily fits in cache.
>> Is this behavior standardized or merely implementation-defined? I'm not
>> interested in writing code that assumes Linux/glibc.
>> Jeff
>> Jeff Hammond
>> http://jeffhammond.github.io/
> Jeff Hammond
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170313/2e8f7795/attachment.sig>
