[petsc-dev] make allfortranstubs
Mon Mar 13 12:53:21 CDT 2017
On Mon, Mar 13, 2017 at 12:52 PM, Jed Brown <jed at jedbrown.org> wrote:
> Barry Smith <bsmith at mcs.anl.gov> writes:
> >    In other words, write to a file with an alternative name, diff
> between the files and mv over only if the files differ?
> Yes.
> >    Presumably portions of the process of making fortran stubs can be run
> in parallel so as to make the time less painful.
> But might be error-prone to implement.
I think it would be a lot easier if someone moved the easy, parsing stuff
to Python, and then used the subprocess
module to do easy, independent tasks in separate directories.
   Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170313/39974aa6/attachment.html>
