[petsc-dev] make allfortranstubs
Mon Mar 13 12:56:45 CDT 2017
> On Mar 13, 2017, at 12:52 PM, Jed Brown <jed at jedbrown.org> wrote:
> Barry Smith <bsmith at mcs.anl.gov> writes:
>>   In other words, write to a file with an alternative name, diff between the files and mv over only if the files differ?
> Yes.
>>   Presumably portions of the process of making fortran stubs can be run in parallel so as to make the time less painful.
> But might be error-prone to implement.
   Not sure why. I believe that bfort generates completely independently all its files so that can be just gmake magic to do them all in parallel. Yes, the
processing we do after that is best left sequential.
