[petsc-dev] make allfortranstubs
Jed Brown jed at jedbrown.org
Mon Mar 13 12:52:08 CDT 2017
Barry Smith <bsmith at mcs.anl.gov> writes:
>    In other words, write to a file with an alternative name, diff between the files and mv over only if the files differ?
Yes.
>    Presumably portions of the process of making fortran stubs can be run in parallel so as to make the time less painful.
But might be error-prone to implement.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170313/2a832f19/attachment.sig>
