[petsc-dev] petscversion.h unchanged but API changed for MatGetSubMatrix and others
Eric Chamberland Eric.Chamberland at giref.ulaval.ca
Fri Mar 10 08:52:52 CST 2017
Juste compiled with last night tarball of petsc-master and found that
MatGetSubMatrix has changed to MatCreateSubMatrix.
Fine, but I can't use the petscversion.h to switch into my code with
#ifdef over any of:
#define PETSC_VERSION_MAJOR      3
#define PETSC_VERSION_MINOR      7
#define PETSC_VERSION_SUBMINOR   5
#define PETSC_VERSION_PATCH      0
since it is unchanged with 3.7.5.0 which has a different api.
Would someone please change the version?
Eric
