[petsc-dev] petsc patch number
Kong, Fande fande.kong at inl.gov
Wed Apr 19 11:37:50 CDT 2017
On Wed, Apr 19, 2017 at 10:27 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Wed, 19 Apr 2017, Kong, Fande wrote:
> > On Wed, Apr 19, 2017 at 9:59 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> > > Why do you need to distinguish (between petsc maint snapshots) if you
> > > are using the fixed superlu_dist version with both?
> > The old one has been complied several months ago, and we do not want to
> > recompile it,
> What do you mean by old? PETSc-3.6.4, or PETSc-3.7.5? [or both?]
PETSc-3.7.5
> > and most of tests stay with this version.
> Which version?
3.7.5
> > The current patched one is used for a few tests only.
> How would you do that? Is that a 3rd test run in addition to the above
> two?
Yes, this is a 3rd test run.
> If so why do you need version info here [why not run the third
> test with the extra configure option I mentioned with petsc-3.7.5 or
> whatever 'maint' snapshot your test scripts can grab?[
> Or why not fix your test scripts to grab URLs - and not hardcode version
> info?
> >  It is not that trivial for me to update all user side applications
> > with petsc. We therefore avoid updating petsc frequently.
> You appear to have basic misunderstanding about petsc patch
> releases. As Jed mentioned the API is not supporsed to change with
> patch releases so you shouldn't have to 'update user side
> applications'.
I know that APIs do not change, but this does not mean that numerical
behaviors  will stay the same.
> Anyway - I guess I don't really understand the problem you are trying
> to solve - and how a different petsc 'version' helps with it.
> Perhaps a 3.7.6 release will help. You'll have to wait for that.
I have to wait for 3.7.6. When it will be released?
Fande,
> Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170419/1b803743/attachment.html>
