[petsc-dev] Fwd: Errored: petsc/petsc#850 (master - 66b078f)
Wed Oct 26 19:41:00 CDT 2016
Who runs these? Is it us?
     Matt
---------- Forwarded message ----------
Date: Wed, Oct 26, 2016 at 7:01 PM
Subject: Errored: petsc/petsc#850 (master - 66b078f)
To: knepley at gmail.com
*petsc / petsc <https://travis-ci.org/petsc/petsc>* (master
<https://github.com/petsc/petsc/tree/master>)
Build #850 has errored. <https://travis-ci.org/petsc/petsc/builds/170919758>
2 hours, 31 minutes, and 1 second
*Matthew G. Knepley* 66b078f
<https://github.com/petsc/petsc/commit/66b078fbae2fa601457180136c1f61ed400fa257>
Changeset
→ <https://github.com/petsc/petsc/compare/ae337d2f9966...66b078fbae2f>
  Merge branch 'knepley/feature-plex-bdfunc'
* knepley/feature-plex-bdfunc: (56 commits)
updated snes/ex56
updated snes/ex56
Plex: Goddamn it! Shadowing a variable name
PetscDS: Must be setup in order to access field sizes and components
fix bad merge 44ac993612e1ca111ab14eba1c22039e0ba32a12 wrt
src/snes/examples/tutorials/ex56.c [by attempting to redo the merge with
kdiff3 - and then comparing the final result with the result in the above
merge]
fixed snes/ex56 for PetscDSAddBoundary change
dmplexsnes: Remove more unused variables
Remove unused variables
SNES ex77: Must also set face quadrature
SNES ex12: No longer need boundary discretization orders
SNES ex62: Numerical flutter
SNES ex12: Numerical flutter
Plex: In projection, get Nc from DS instead of calculating it again
PetscFE: Added missing destroy
SNEX ex77: Update boundary args and FE creation
Plex: Update boundary integrals to new API
SNES ex12: Tests of bc from fields
SNES ex12: Added the ability to use finite element fields as boundary
conditions
Plex: Need invJ for field projection
Plex: Fix bug with field projection - We must tabulate the FE on the dual
basis quadrature points
*Want to know about upcoming build environment updates?*
Would you like to stay up-to-date with the upcoming Travis CI build
environment updates? We set up a mailing list for you! Sign up here
<http://eepurl.com/9OCsP>.
Documentation <https://docs.travis-ci.com> about Travis CI
Need help? Mail support <support at travis-ci.com>!
Choose who receives these build notification emails in your configuration
file <https://docs.travis-ci.com/user/notifications>.
*Would you like to test your private code?*
Travis CI for Private Projects
<https://travis-ci.com?utm_source=build_email_footer&utm_campaign=travis-ci.org&utm_medium=email>
could be your new best friend!
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20161026/d0f262a3/attachment.html>
