[petsc-dev] Errored: petsc/petsc#850 (master - 66b078f)
Wed Oct 26 19:57:43 CDT 2016
  Matt,
 Lisandro set  this up. Occasionally strange "package" type errors before it really gets to PETS and then it runs out of time sometimes. Annoying, but seemingly not much one can do about it.  I guess it is limitations of Travis.... So you can bug Lisandro, good luck
   Barry
> On Oct 26, 2016, at 7:41 PM, Matthew Knepley <knepley at gmail.com> wrote:
> Who runs these? Is it us?
>   Thanks,
>      Matt
> ---------- Forwarded message ----------
> From: Travis CI <builds at travis-ci.org>
> Date: Wed, Oct 26, 2016 at 7:01 PM
> Subject: Errored: petsc/petsc#850 (master - 66b078f)
> To: knepley at gmail.com
>   petsc / petsc (master)
> Build #850 has errored.	 2 hours, 31 minutes, and 1 second
> 	Matthew G. Knepley	66b078f Changeset →
>  	Merge branch 'knepley/feature-plex-bdfunc'
> * knepley/feature-plex-bdfunc: (56 commits)
> updated snes/ex56
> updated snes/ex56
> Plex: Goddamn it! Shadowing a variable name
> PetscDS: Must be setup in order to access field sizes and components
> fix bad merge 44ac993612e1ca111ab14eba1c22039e0ba32a12 wrt src/snes/examples/tutorials/ex56.c [by attempting to redo the merge with kdiff3 - and then comparing the final result with the result in the above merge]
> fixed snes/ex56 for PetscDSAddBoundary change
> dmplexsnes: Remove more unused variables
> Remove unused variables
> SNES ex77: Must also set face quadrature
> SNES ex12: No longer need boundary discretization orders
> SNES ex62: Numerical flutter
> SNES ex12: Numerical flutter
> Plex: In projection, get Nc from DS instead of calculating it again
> PetscFE: Added missing destroy
> SNEX ex77: Update boundary args and FE creation
> Plex: Update boundary integrals to new API
> SNES ex12: Tests of bc from fields
> SNES ex12: Added the ability to use finite element fields as boundary conditions
> Plex: Need invJ for field projection
> Plex: Fix bug with field projection - We must tabulate the FE on the dual basis quadrature points
> Want to know about upcoming build environment updates?
> Would you like to stay up-to-date with the upcoming Travis CI build environment updates? We set up a mailing list for you! Sign up here.
>  	Documentation about Travis CI
> Need help? Mail support!
> Choose who receives these build notification emails in your configuration file.
> Would you like to test your private code?
> Travis CI for Private Projects could be your new best friend!
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
