[petsc-dev] strangness in Chebyshev estimate of eigenvalues
Jed Brown jed at jedbrown.org
Wed May 25 10:52:04 CDT 2016
Mark Adams <mfadams at lbl.gov> writes:
> Is rebase -i going to work?
Yes.
> I read:
> git rebase -i master
> Note that rebasing to the master does not work if you merged the master
> into your feature branch while you were working on the new feature. If you
> did this you will need to find the original branch point and call git
> rebase with
> a SHA1 revision.
Where did you read the above?
> So I was pulling from master all the time, by mistake.  If I do a rebase -i
> with /jed/mark/snes-ex56c, will it give me all of the branch to squash?
Yes.  Note that you may still want distinct commits.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160525/d0c5df5d/attachment.sig>
