[petsc-dev] strangness in Chebyshev estimate of eigenvalues
Mark Adams mfadams at lbl.gov
Wed May 25 10:29:17 CDT 2016
Is rebase -i going to work?  I read:
git rebase -i master
Note that rebasing to the master does not work if you merged the master
into your feature branch while you were working on the new feature. If you
did this you will need to find the original branch point and call git
rebase with
a SHA1 revision.
So I was pulling from master all the time, by mistake.  If I do a rebase -i
with /jed/mark/snes-ex56c, will it give me all of the branch to squash?
On Wed, May 25, 2016 at 8:16 AM, Mark Adams <mfadams at lbl.gov> wrote:
> On Wed, May 25, 2016 at 8:00 AM, Jed Brown <jed at jedbrown.org> wrote:
>> Mark Adams <mfadams at lbl.gov> writes:
>> > FYI, I get this error from rebasing. I will look into what they suggest.
>> What command did you use to rebase?
> git rebase master
>> I ran "git rebase master" and fixed one trivial conflict in a makefile.
>> The result is in 'jed/mark/snes-ex56c' if you want to check it out.
> thanks, got it.
>> > warning: squelched 32 whitespace errors
>> > warning: 37 lines add whitespace errors.
>> > Falling back to patching base and 3-way merge...
>> > Auto-merging config/builder.py
>> > CONFLICT (content): Merge conflict in config/builder.py
>> > error: Failed to merge in the changes.
>> > Patch failed at 0029 Adding tests for dmplex adaptation
>> > The copy of the patch that failed is found in: .git/rebase-apply/patch
>> > When you have resolved this problem, run "git rebase --continue".
>> > If you prefer to skip this patch, run "git rebase --skip" instead.
>> > To check out the original branch and stop rebasing, run "git rebase
>> > --abort".
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160525/2878c383/attachment.html>
