[petsc-dev] Configure push
Mon Jun 6 13:08:34 CDT 2016
On Mon, 6 Jun 2016, Matthew Knepley wrote:
> On Mon, Jun 6, 2016 at 5:27 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > Matt,
> > Per integration workflow - all feature branches should be tested
> > locally (and be complete) - before merged to next [next is for
> > integration testing - not feature testing]
> > You could have used (modified):
> > config/examples/arch-linux-xsdk-dbg.py
> > config/examples/arch-osx-xsdk-opt.py
> > Yeah - we don't have automatic 'feature branch test before integration
> > testing' workflow - so currently this has to be done manually.
> I don't really have the OS/compiler options available to test things
> exhaustively, so I am
> using next for this. I think this is acceptable right now.
Well then the feature is not yet ready for next - and could have
waited until it was ready.
If it was for someone to use - then they could have used the
feature-branch..
The workflow requires the feature to be complete - and minimally
tested - before merge to next.. We do ocassionally take shortcuts -
but this sometimes this results in extended broken next...
Satish
