[petsc-dev] Configure push
Mon Jun 6 12:44:13 CDT 2016
On Mon, Jun 6, 2016 at 5:27 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> Matt,
> Per integration workflow - all feature branches should be tested
> locally (and be complete) - before merged to next [next is for
> integration testing - not feature testing]
> You could have used (modified):
> config/examples/arch-linux-xsdk-dbg.py
> config/examples/arch-osx-xsdk-opt.py
> Yeah - we don't have automatic 'feature branch test before integration
> testing' workflow - so currently this has to be done manually.
I don't really have the OS/compiler options available to test things
exhaustively, so I am
using next for this. I think this is acceptable right now.
    Matt
> Satish
> On Mon, 6 Jun 2016, Matthew Knepley wrote:
> > I have pushed configure changes to next. They mainly concern the changes
> > made to support xSDK. Do we have a nightly test for this?
> > Those changes broke the configure encapsulation by directly depending on
> > PETSc. I have removed this dependence, but it would be good if we checked
> > that this did not break anything for xSDK.
> >   Thanks,
> >      Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160606/1fd8ca53/attachment.html>
