[petsc-dev] Configure push
Mon Jun 6 11:27:26 CDT 2016
Matt,
Per integration workflow - all feature branches should be tested
locally (and be complete) - before merged to next [next is for
integration testing - not feature testing]
You could have used (modified):
config/examples/arch-linux-xsdk-dbg.py
config/examples/arch-osx-xsdk-opt.py
Yeah - we don't have automatic 'feature branch test before integration
testing' workflow - so currently this has to be done manually.
Satish
On Mon, 6 Jun 2016, Matthew Knepley wrote:
> I have pushed configure changes to next. They mainly concern the changes
> made to support xSDK. Do we have a nightly test for this?
> Those changes broke the configure encapsulation by directly depending on
> PETSc. I have removed this dependence, but it would be good if we checked
> that this did not break anything for xSDK.
>   Thanks,
>      Matt
