[petsc-dev] git repo branches housekeeping
Mon Apr 25 13:38:11 CDT 2016
http://stackoverflow.com/questions/12495756/why-doesnt-git-allow-me-to-safely-delete-a-branch/12520718
Ah - I think you've done the following (or equivalent)- so git is complaining.
git checkout barry/download-mstk
<edit/test>
git commit
[did not do 'git push']
git checkout master
git merge barry/download-mstk
Since these branches are already merged to 3.7 - and also deleted on
remote/server - you can 'force delete' the local ones.
git branch -D barry/download-mstk shri/add-tsevent-to-powergrid-examples
[also 'git fetch -p']
Satish
On Mon, 25 Apr 2016, Barry Smith wrote:
> $ git log v3.7..shri/add-tsevent-to-powergrid-example
> fatal: ambiguous argument 'v3.7..shri/add-tsevent-to-powergrid-example': unknown revision or path not in the working tree.
> Use '--' to separate paths from revisions, like this:
> 'git <command> [<revision>...] -- [<file>...]'
> ~/Src/petsc (next=)
> $ git log v3.7..barry/download-mstk
> ~/Src/petsc (next=)
> > On Apr 25, 2016, at 1:12 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > What do you have for
> > git fetch
> > got lpg v3.7..shri/add-tsevent-to-powergrid-examples
> > Satish
> >> warning: not deleting branch 'barry/download-mstk' that is not yet merged to
> >>         'refs/remotes/origin/barry/download-mstk', even though it is merged to HEAD.
> >> error: The branch 'barry/download-mstk' is not fully merged.
> >> If you are sure you want to delete it, run 'git branch -D barry/download-mstk'.
> >> warning: not deleting branch 'shri/add-tsevent-to-powergrid-examples' that is not yet merged to
> >>         'refs/remotes/origin/shri/add-tsevent-to-powergrid-examples', even though it is merged to HEAD.
> >> error: The branch 'shri/add-tsevent-to-powergrid-examples' is not fully merged.
> >> If you are sure you want to delete it, run 'git branch -D shri/add-tsevent-to-powergrid-examples'.
> >>> On Apr 25, 2016, at 12:01 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> >>> ref: http://lists.mcs.anl.gov/pipermail/petsc-dev/2015-June/017808.html
> >>> I've deleted all deveopment branches that are already merged into
> >>> maint (v3.7) from https://bitbucket.org/petsc/petsc
> >>> However if you wish to remove these branches from your clone - it has
> >>> to be done manually (in each clone).
> >>> To get this list of branches to delete - you can do:
> >>> git branch --merged v3.7 |egrep -v " (maint|master|next)" > branches_to_delete
> >>> After *verifying* the list is correct - and ok to delete - they can be deleted with:
> >>> git branch -d `cat branches_to_delete`
> >>> And to sync the [deleted] remove branch list info - you can do:
> >>> git fetch -p
> >>> For more housekeeping - look at the remaining local and remote
> >>> branches and figure-out what to do. [perhaps some of them are
> >>> intermediate branches during rebase - or abandoned features that
> >>> should be deleted]. For my branches - I would do:
> >>> git branch
> >>> git branch -r |grep balay
> >>> Satish
> >>> reference for self:
> >>> $ git branch -r --merged v3.7 |egrep  -v origin/\(maint\|master\|next\) |sed -e s%origin/%:% >  remote_branches_to_delete
> >>> $ git push -u origin `cat remote_branches_to_delete`
> >>> To git at bitbucket.org:petsc/petsc.git
> >>> - [deleted]         Fande-Kong/moved-partitioning-to-pcgasmsetup
> >>> - [deleted]         balay-to-maint-fix-vs2015-vsnprintf
> >>> - [deleted]         balay/add-KSPComputeRitz-patch
> >>> - [deleted]         balay/add-clang-sa-build
> >>> - [deleted]         balay/add-fortran-DMRemoveLabel
> >>> - [deleted]         balay/configure-pkg-git-autoupdate
> >>> - [deleted]         balay/el-parmetis-check
> >>> - [deleted]         balay/el_AxpyInterface_removal
> >>> - [deleted]         balay/fix-externalpackage-build-shared
> >>> - [deleted]         balay/fix-fortran-unused_variables
> >>> - [deleted]         balay/fix-sowing-valgrind
> >>> - [deleted]         balay/fix-streams-npmax
> >>> - [deleted]         balay/fix-win-isnan
> >>> - [deleted]         balay/ftn-command_argument
> >>> - [deleted]         balay/git-externalpackage-update
> >>> - [deleted]         balay/improve-odpes
> >>> - [deleted]         balay/rm-tree
> >>> - [deleted]         balay/superlu_dist-4.3
> >>> - [deleted]         balay/superlu_dist-4.3-p1
> >>> - [deleted]         balay/to-maint-add-mpiuni_mpi_in_place
> >>> - [deleted]         balay/to-maint-add-urlretrieve-timeout
> >>> - [deleted]         balay/to-maint-fix-fortran-fflag-order
> >>> - [deleted]         balay/to-maint-fix-gfortran51-warnings
> >>> - [deleted]         balay/to-maint-fix-win64-long
> >>> - [deleted]         balay/to-maint-metis-parmetis-nocxx
> >>> - [deleted]         balay/to-maint-migrate-builds
> >>> - [deleted]         balay/to-maint/update-superlu_dist-4.1
> >>> - [deleted]         balay/update-elemental-0.86-pre
> >>> - [deleted]         balay/update-gmake-check
> >>> - [deleted]         balay/update-gnumake-41
> >>> - [deleted]         balay/update-metis-xcode-fix-to-maint
> >>> - [deleted]         balay/update-mpich-3.2
> >>> - [deleted]         balay/update-sowing-svn
> >>> - [deleted]         balay/update-superlu_dist_mar-16-294e2d0
> >>> - [deleted]         barry-allow-vecset-nan-3.6
> >>> - [deleted]         barry/Sylvain-gmres-symmetric
> >>> - [deleted]         barry/add-concurrencykit
> >>> - [deleted]         barry/add-dmdavecgetarrayreadf90/maint
> >>> - [deleted]         barry/add-dmshellcreaterestriction
> >>> - [deleted]         barry/add-mpiu_allreduce
> >>> - [deleted]         barry/add-pcfieldsplit-logevent
> >>> - [deleted]         barry/add-pcreset-hypre
> >>> - [deleted]         barry/add-pcreset-hypre-for-master
> >>> - [deleted]         barry/all-petscoptionssetvalue-beforepetscinitialize
> >>> - [deleted]         barry/always-mark-floats
> >>> - [deleted]         barry/better-matsetoption-error
> >>> - [deleted]         barry/check-for-PetscInt-overflow
> >>> - [deleted]         barry/check-nullspace-properties
> >>> - [deleted]         barry/cleanup-pcsetupcalled
> >>> - [deleted]         barry/cleanup-petscsys
> >>> - [deleted]         barry/download-mstk
> >>> - [deleted]         barry/download-pflowtran
> >>> - [deleted]         barry/downloads
> >>> - [deleted]         barry/error-on-extern-c-of-petscincludes
> >>> - [deleted]         barry/feature-force-setting-exactfinaltime
> >>> - [deleted]         barry/feature-linesearch-monitor
> >>> - [deleted]         barry/feature-ts-monitor-binary
> >>> - [deleted]         barry/fix-dmnetworkcomponentalignment
> >>> - [deleted]         barry/fix-log-summary-format
> >>> - [deleted]         barry/fix-matgetlocalsubmatrix
> >>> - [deleted]         barry/fix-matheaderreplace
> >>> - [deleted]         barry/fix-matseqaijgetarrayf90
> >>> - [deleted]         barry/fix-mg-coarse-ksp-defaults
> >>> - [deleted]         barry/fix-mg-coarse-redundant
> >>> - [deleted]         barry/fix-mpiuni
> >>> - [deleted]         barry/fix-mumps-destroy
> >>> - [deleted]         barry/fix-nonew-notcollective/maint
> >>> - [deleted]         barry/fix-petscviewer-attempt-2
> >>> - [deleted]         barry/fix-private-functions
> >>> - [deleted]         barry/fix-stageevent-idtypes
> >>> - [deleted]         barry/fix-ts-matshift-error
> >>> - [deleted]         barry/fix-win-e-00
> >>> - [deleted]         barry/fix-xsdktrilinos
> >>> - [deleted]         barry/fixes-for-release-1
> >>> - [deleted]         barry/improve-git-download
> >>> - [deleted]         barry/improve-minres
> >>> - [deleted]         barry/improve-opt-handling
> >>> - [deleted]         barry/improve-ts-monitor-interpolation
> >>> - [deleted]         barry/list-downloads
> >>> - [deleted]         barry/maint/fix-snessetupdate-fortran
> >>> - [deleted]         barry/maint/mv-matnullspace-to-mat
> >>> - [deleted]         barry/make-nonstatic-petscviewerflowcontrol
> >>> - [deleted]         barry/master/fix-cuda-extern-c
> >>> - [deleted]         barry/monitor-fromoptions
> >>> - [deleted]         barry/not-single-precision
> >>> - [deleted]         barry/optimize-xolotl
> >>> - [deleted]         barry/petscoptions-object
> >>> - [deleted]         barry/remove-matmffdaddnullspace/master
> >>> - [deleted]         barry/remove-pc-nonzero-guess
> >>> - [deleted]         barry/remove-pcsetup-mg-changeofpreonly/master
> >>> - [deleted]         barry/remove-unneed-tao-tolerances
> >>> - [deleted]         barry/shell-update-vector-states
> >>> - [deleted]         barry/simplify-test-jobs
> >>> - [deleted]         barry/update-hypre
> >>> - [deleted]         barry/update-monitors
> >>> - [deleted]         barry/update-petscmemoryshowusage
> >>> - [deleted]         barry/update-superlu
> >>> - [deleted]         barry/update-superlu_dist
> >>> - [deleted]         barry/update-superlu_dist-again
> >>> - [deleted]         barry/various-fixes
> >>> - [deleted]         barry/xml-nested-logging
> >>> - [deleted]         dalcinl/ts-2nd-order-systems
> >>> - [deleted]         dalcinl/tsbdf
> >>> - [deleted]         dmay/PetscSubcommDestroy-manpage
> >>> - [deleted]         emil/doc-add-error-control
> >>> - [deleted]         emil/fix-arkimex-diverged-reason
> >>> - [deleted]         emil/fix-manual-typos-in-ts
> >>> - [deleted]         emil/fix-ts-euler-generate-error-if-non-rhsfunction
> >>> - [deleted]         emil/to-maint-fix-euler-interpolation
> >>> - [deleted]         emil/to-maint-fix-ts-reporting-nonembedded
> >>> - [deleted]         hongzh/add-checkpointing-support-for-adaptive-ts
> >>> - [deleted]         hongzh/add-ts-trajectory-statistics
> >>> - [deleted]         hongzh/checkpointing
> >>> - [deleted]         hongzh/checkpointing-update
> >>> - [deleted]         hongzh/fix-bug-for-cost-integral
> >>> - [deleted]         hongzh/update-revolve
> >>> - [deleted]         hongzh/update-ts-trajectory
> >>> - [deleted]         hzhang/dmnetwork-spJacobian
> >>> - [deleted]         hzhang/dmnetwork-spJacobian1
> >>> - [deleted]         hzhang/dmnetwork-spJacobian2
> >>> - [deleted]         hzhang/dmnetworkmonitor
> >>> - [deleted]         hzhang/fix-pcredundant
> >>> - [deleted]         hzhang/fix-ptapfill
> >>> - [deleted]         hzhang/fix-superlu_dist
> >>> - [deleted]         hzhang/inode-erroriffpe
> >>> - [deleted]         hzhang/matconvert-den2el
> >>> - [deleted]         hzhang/matgetsubmat_sbaij1
> >>> - [deleted]         hzhang/matmatmult_crmax
> >>> - [deleted]         hzhang/matmatmult_dense
> >>> - [deleted]         hzhang/matpackage-erroriffpe
> >>> - [deleted]         hzhang/matpackage-type
> >>> - [deleted]         hzhang/mattransmatmult_dense
> >>> - [deleted]         hzhang/mumps-getseterrorflg
> >>> - [deleted]         hzhang/opt-ptap
> >>> - [deleted]         hzhang/superlu-5.1
> >>> - [deleted]         hzhang/superlu_dist-4.3-ex17
> >>> - [deleted]         hzhang/update-networkex
> >>> - [deleted]         hzhang/update-networkex-header
> >>> - [deleted]         jed/dmdarestoreelements-strict
> >>> - [deleted]         jed/fix-cuda-deps
> >>> - [deleted]         jed/fix-ksp-norm-none
> >>> - [deleted]         jed/fix-ml-visibility
> >>> - [deleted]         jed/mat-assembly-perf
> >>> - [deleted]         jed/process-options-handler
> >>> - [deleted]         jed/workaround-mpich-naughty-ibarrier
> >>> - [deleted]         jose/veccuda-complex
> >>> - [deleted]         karlrupp/feature-ViennaCL-1.7.x
> >>> - [deleted]         karlrupp/fix-matrixmarket-viewer
> >>> - [deleted]         karlrupp/fix-petscinitialize-cuda
> >>> - [deleted]         karpeev/fix-pcgasm-reuse
> >>> - [deleted]         karpeev/fix-snes-test-docs
> >>> - [deleted]         karpeev/maint-fix-gnupackage-ldflags
> >>> - [deleted]         knepley/dm-fix-header-docs
> >>> - [deleted]         knepley/doc-snes-ex1
> >>> - [deleted]         knepley/feature-dmda-add-accessors
> >>> - [deleted]         knepley/feature-drand48-portable
> >>> - [deleted]         knepley/feature-ds-copy
> >>> - [deleted]         knepley/feature-ex5-mms
> >>> - [deleted]         knepley/feature-ex5-mms-params
> >>> - [deleted]         knepley/feature-label-empty-stratum
> >>> - [deleted]         knepley/feature-mpfr
> >>> - [deleted]         knepley/feature-patrick-control-problem
> >>> - [deleted]         knepley/feature-plex-add-time
> >>> - [deleted]         knepley/feature-plex-handle-func-failure
> >>> - [deleted]         knepley/feature-plex-jacp
> >>> - [deleted]         knepley/feature-plex-ordering-group
> >>> - [deleted]         knepley/feature-plex-point-location
> >>> - [deleted]         knepley/feature-snes-deflation
> >>> - [deleted]         knepley/feature-snes-setfunctionnorm
> >>> - [deleted]         knepley/fix-configure-HOME
> >>> - [deleted]         knepley/fix-configure-compiler-log
> >>> - [deleted]         knepley/fix-configure-dirs
> >>> - [deleted]         knepley/fix-configure-logging
> >>> - [deleted]         knepley/fix-configure-ml
> >>> - [deleted]         knepley/fix-configure-relative-installdir
> >>> - [deleted]         knepley/fix-configure-saving
> >>> - [deleted]         knepley/fix-dm-clone-coord-section
> >>> - [deleted]         knepley/fix-dm-clone-coordinates
> >>> - [deleted]         knepley/fix-dt-tanhsinh
> >>> - [deleted]         knepley/fix-error-messages
> >>> - [deleted]         knepley/fix-ex5-coords-empty
> >>> - [deleted]         knepley/fix-ex5-patchwise
> >>> - [deleted]         knepley/fix-examples-plex
> >>> - [deleted]         knepley/fix-is-fortran
> >>> - [deleted]         knepley/fix-msm-opt
> >>> - [deleted]         knepley/fix-pc-composite-dm
> >>> - [deleted]         knepley/fix-pc-msm
> >>> - [deleted]         knepley/fix-plex-blocksize
> >>> - [deleted]         knepley/fix-plex-c89
> >>> - [deleted]         knepley/fix-plex-create-fortran
> >>> - [deleted]         knepley/fix-plex-distribute-label
> >>> - [deleted]         knepley/fix-plex-e12-3d
> >>> - [deleted]         knepley/fix-plex-ex1f90
> >>> - [deleted]         knepley/fix-plex-examples
> >>> - [deleted]         knepley/fix-plex-general-interp
> >>> - [deleted]         knepley/fix-plex-hdf5-label
> >>> - [deleted]         knepley/fix-plex-l2diff
> >>> - [deleted]         knepley/fix-plex-natural-mem
> >>> - [deleted]         knepley/fix-plex-point-location
> >>> - [deleted]         knepley/fix-plex-pragmatic-marking
> >>> - [deleted]         knepley/fix-plex-regression
> >>> - [deleted]         knepley/fix-plex-test-partitions
> >>> - [deleted]         knepley/fix-quadrature-test
> >>> - [deleted]         knepley/fix-seterrq-doc
> >>> - [deleted]         knepley/fix-snes-ex5-mms
> >>> - [deleted]         knepley/fix-snesqn-fortran
> >>> - [deleted]         knepley/fix-solkx
> >>> - [deleted]         knepley/plex-filter
> >>> - [deleted]         knepley/remove-pbgl
> >>> - [deleted]         knepley/snes-ex5-mms
> >>> - [deleted]         knepley/test-asm-empty-subdomain
> >>> - [deleted]         mark/eigen-rand
> >>> - [deleted]         mark/gamg-crs
> >>> - [deleted]         mark/gamg-rand
> >>> - [deleted]         mesgarnejad/feature-plex-globaltonatural
> >>> - [deleted]         mlange/fix-plex-fluent-reader
> >>> - [deleted]         mlange/fix-plex-multi-level-overlap
> >>> - [deleted]         pefarrell/tao-set-riesz-map
> >>> - [deleted]         pr263/PierreBdR/ts-domain-error-in-stage/master
> >>> - [deleted]         pr330/knepley/dmshell-set-create-subdm/master
> >>> - [deleted]         pr332/master/Fande-Kong/mat-increaseoverlap-scalable
> >>> - [deleted]         pr345/anriseth/anriseth/ngmres-reset-xm-increase/master
> >>> - [deleted]         pr349/mapdes/extend_hypre_boomeramg_interface/master
> >>> - [deleted]         pr352/dmay/pctelescope/master
> >>> - [deleted]         pr353/dmeiser/fix-ex2_bjacobi-update/master
> >>> - [deleted]         pr353/dmeiser/fix-ex2_bjacobi/master
> >>> - [deleted]         pr358/buptphyphy/addmatcreatenormalhermitian/master
> >>> - [deleted]         pr361/master/Fande-Kong/pcgasm-increaseoverlap
> >>> - [deleted]         pr369/Fande-Kong/fixed-comment-space/master
> >>> - [deleted]         pr372/vijaysm/vijaysm/moab_ts_examples_fix/master
> >>> - [deleted]         pr380/semihozmen/semihozmen/ksp-eigen-comp-bugfix/master
> >>> - [deleted]         pr384/Fande-Kong/fix-pcgasm-reuse/master
> >>> - [deleted]         pr388/mapdes/fix-petscsf-create-section-sf/master
> >>> - [deleted]         pr391/zianekhodja/lilia/tsirm/master
> >>> - [deleted]         pr394/stevengcj/blassuffix/master
> >>> - [deleted]         pr395/dmeiser/fix-veccuspgetarraywrite/master
> >>> - [deleted]         pr401/tferma/virs-pcfieldsplit-fix/master
> >>> - [deleted]         pr403/pascgeopc/psanan/ksp-pipe-flex/master
> >>> - [deleted]         pr404/tferma/virs-divergedlinearsolve-fix-rebase/master
> >>> - [deleted]         pr408/psanan/psanan/pc-bddc-view/master
> >>> - [deleted]         pr412/psanan/psanan/ksp-cg-separate-singlereduction/master
> >>> - [deleted]         pr413/scools/siegfriedcools/pipecgrr/master
> >>> - [deleted]         pr417/adam_qc/fix-tao-ls-view-typo/master
> >>> - [deleted]         pr421/alex/feature-veccuda
> >>> - [deleted]         pr426/dmay/dmay/pctelescope-mods/master
> >>> - [deleted]         pr428/bug-fixes-for-viennaclseqaij
> >>> - [deleted]         psanan/benchmarks-cleanup
> >>> - [deleted]         psanan/ksp-fgmres-reduce-alloc
> >>> - [deleted]         sanderarens/fix-plex-neumann-bc
> >>> - [deleted]         sarich/check-fcflags-fflags
> >>> - [deleted]         sarich/feature-tao-pounders-add-correlations
> >>> - [deleted]         sarich/fix-tao-man-objgrad
> >>> - [deleted]         sarich/fix-vec-stepbound
> >>> - [deleted]         sarich/fix-xsdk-packages
> >>> - [deleted]         sarich/jenkins
> >>> - [deleted]         shri/add-tsevent-to-powergrid-examples
> >>> - [deleted]         stefano_zampini/enable-matcreatevecs-without-preallocation
> >>> - [deleted]         stefano_zampini/feature-fetidp-classes
> >>> - [deleted]         stefano_zampini/feature-pardiso-schur
> >>> - [deleted]         stefano_zampini/feature-ptap-seqdense
> >>> - [deleted]         stefano_zampini/feature-zerorowscolumns-seqdense
> >>> - [deleted]         stefano_zampini/fix-for-release
> >>> - [deleted]         stefano_zampini/fix-static-analyzer
> >>> - [deleted]         stefano_zampini/matis-feature-localtoglobalmap-handling
> >>> - [deleted]         stefano_zampini/matis-fix-create
> >>> - [deleted]         stefano_zampini/somefixes-matdense-lda
> >>> - [deleted]         tisaac/buildCheck-ignore-vc-moaning
> >>> - [deleted]         tisaac/buildsystem-fix-pic
> >>> - [deleted]         tisaac/dm-label-promote
> >>> - [deleted]         tisaac/dm-locate-points-sf
> >>> - [deleted]         tisaac/dmforest
> >>> - [deleted]         tisaac/dmp4est-feature-injection
> >>> - [deleted]         tisaac/dmplex-stable-tet-refinement
> >>> - [deleted]         tisaac/dt-fix-geom-punning
> >>> - [deleted]         tisaac/fix-static-analysis-warnings
> >>> - [deleted]         tisaac/plex-feature-tree-fv
> >>> - [deleted]         tisaac/plex-fix-ex3-const
> >>> - [deleted]         tisaac/plex-fix-ex3-failure-message
> >>> - [deleted]         tisaac/plex-fix-single-prec
> >>> - [deleted]         tisaac/sf-fix-multi-sf-leaves
> >>> - [deleted]         tomklotz/feature-tanh-sinh-quadrature
