[petsc-dev] git repo branches housekeeping
Mon Apr 25 14:03:43 CDT 2016
On Mon, 25 Apr 2016, Satish Balay wrote:
> For more housekeeping - look at the remaining local and remote
> branches and figure-out what to do. [perhaps some of them are
> intermediate branches during rebase - or abandoned features that
> should be deleted]. For my branches - I would do:
For reference - current list of remote branches
Satish
$ git branch -r |wc -l
196
$ git branch -r
  origin/HEAD -> origin/master
  origin/PICell
  origin/adams/zeroDSOR
  origin/balay/atpesc-tutorial-2014-bgq
  origin/balay/atpesc-tutorial-2015-bgq
  origin/balay/fix-cxx-cmplx-single
  origin/balay/fix-uninstall
  origin/balay/giturl-fixes
  origin/balay/to-maint-switch-hdf5-build-to-cmake
  origin/balay/update-cmake-3.3
  origin/balay/update-hdf5-netcdf
  origin/barry/check-no-autodetect-first
  origin/barry/cleanup-checkclibraries
  origin/barry/feature-enhanced-binary-viewers
  origin/barry/fix-petscviewer-attempt-1
  origin/barry/fix-some-clang-warnings
  origin/barry/fix-threadsafety-mpi-key-value-create
  origin/barry/html
  origin/barry/more-tchem-work
  origin/barry/new-test-makefiles
  origin/barry/newhtml
  origin/barry/saws-profile
  origin/barry/superlu_mt
  origin/barry/utilize-hwloc
  origin/bueler/clean-ex9
  origin/dalcinl/fix-xaij-spd
  origin/dalcinl/malloc-coalesced
  origin/dalcinl/ts-exactfinaltime
  origin/debo/mat-taij
  origin/debo/ts-fix-ex31
  origin/debo/ts-irk
  origin/dmay/ksp-cvgtest-normtype-fix
  origin/emil/fix-ts-dae-rebased-v2
  origin/emil/ts-glee
  origin/hongzh/ts-direct-sa
  origin/hongzh/ts-matshell-example
  origin/hzhang/dmnetwork-spJacobian3
  origin/hzhang/fix-ptaptest
  origin/hzhang/ksp-fminres
  origin/hzhang/ksp-minresqlp
  origin/hzhang/superlu_dist-4.3-erroriffpe
  origin/irving/fe-scalars
  origin/irving/snes-ex12-cleanup
  origin/jed/assembly-perf
  origin/jed/cray-externc
  origin/jed/defined-nocpp
  origin/jed/elbueler-snes-ex5-fixes
  origin/jed/feature-dmda-section
  origin/jed/feature-sf-local
  origin/jed/fix-mat-convert-basic-bs
  origin/jed/fix-matnorm-log-flops
  origin/jed/ksp-plugin
  origin/jed/mat-eigenvalue-cache
  origin/jed/mat-taij
  origin/jed/mpi-2
  origin/jed/next-seaice
  origin/jed/sr-driver
  origin/jed/sr-driver4
  origin/jed/tao-status-string
  origin/jed/tap
  origin/jed/ts-ex11-union
  origin/jed/ts-heat-plex
  origin/jed/vecghostgetvalues
  origin/john-saws-webosocket-update
  origin/john/saws-webui-upgrade
  origin/jose/lapack-check
  origin/karlrupp/feature-optimize-opencl-petscfe
  origin/karlrupp/feature-pipelined-cg-viennacl
  origin/karlrupp/feature-viennacl-cuda
  origin/karlrupp/feature-viennacl-openmp
  origin/karlrupp/fix-viennacl-veccopy
  origin/karpeev/fix-pc-fieldsplit-reset
  origin/karpeev/mat-convert-nest-aij-test
  origin/karpeev/mat-reset
  origin/klaij/fieldsplit-simple-ex70
  origin/knepley/feature-configure-kcomputer
  origin/knepley/feature-da-repartition
  origin/knepley/feature-fe-nonaffine
  origin/knepley/feature-optcontrol-mg
  origin/knepley/feature-parallel-mesh-load
  origin/knepley/feature-plex-example-nonconforming
  origin/knepley/feature-plex-nasm
  origin/knepley/feature-spectral-solutions
  origin/knepley/feature-ts-mass-matrix
  origin/knepley/fix-cohesive-orientation
  origin/knepley/fix-quadrature-order
  origin/knepley/pylith
  origin/knepley/swarm
  origin/madams/ex56params
  origin/madams/sor-residual
  origin/madams/sr-driver
  origin/madams/sr-driver2
  origin/madams/sr-driver4
  origin/madams/sr1
  origin/maint
  origin/maint-3.2
  origin/maint-3.3
  origin/maint-3.4
  origin/maint-3.5
  origin/maint-3.6
  origin/maint-tao-2.2
  origin/mark/dmshell-ltogmap
  origin/mark/dmshell-test
  origin/mark/feature-picell
  origin/mark/feature-picell-iter
  origin/mark/gamg-coarse_ksp
  origin/mark/gamg-squarefix
  origin/mark/gamg-zerod
  origin/mark/ksp-zero-its
  origin/mark/schur-D
  origin/mark/tsex11
  origin/master
  origin/master-tao
  origin/mlange/feature-plex-case
  origin/mlange/feature-plex-create-parallel
  origin/mlange/feature-plex-med
  origin/mlange/feature-plex-triangle
  origin/mlange/fix-adjacency-performance
  origin/mlange/fix-plex-cas-tests
  origin/mlange/fix-plex-hex-mesh
  origin/mlange/plex-create-parallel
  origin/mlange/plex-distributed-overlap
  origin/mlange/plex-hybrid-hdf5
  origin/mlange/plex-redistribute
  origin/mlange/plex-sfc-reordering
  origin/mlange/plex-vertex-partitioning
  origin/mlange05/fix-gmsh-coordinates
  origin/next
  origin/next-apr-2016
  origin/next-jun-2015
  origin/next-oct-2014
  origin/paulmullowney/aijcusp-ellpack-fix
  origin/peller/threadcomm
  origin/pr118/asmunder/DMDA-fortran-example/master
  origin/prbrune/matcoloring-creategraph
  origin/prbrune/matcoloring-minpack
  origin/prbrune/matcoloring-misimprovement
  origin/prbrune/matcoloring-zoltan
  origin/prbrune/pcgamg-bootstrap
  origin/prbrune/pcgamg-classicalbootstrap
  origin/prbrune/pcgamg-cr
  origin/prbrune/sf-examplefix
  origin/prbrune/snes-ex19vtkoutput
  origin/prbrune/snes-fasadditive
  origin/prbrune/zoltanupdate
  origin/psanan/ksp-tutorial-ex60-fixes
  origin/psanan/ts-bz-examples
  origin/psanan/ts-multiscale
  origin/psanan/ts-rhs-partitions
  origin/psanan/ts-tests
  origin/psanan/vec-mtdot-fix
  origin/sarich/configure-mira
  origin/sarich/feature-configure-chombo
  origin/sarich/feature-submatrixfree
  origin/sarich/feature-tao-pounders-jacobian
  origin/sarich/feature-tao-pounders-off-diagonal-terms
  origin/sarich/fix-tao-example-add-finalize
  origin/sarich/fix-tao-example-warning
  origin/sarich/mira
  origin/sarich/rnet-all
  origin/sarich/rnet-fix-rebase
  origin/sarich/rnet-import
  origin/sarich/snesvi-subvec-options
  origin/sarich/tao-docs-update
  origin/sarich/tao-lnks
  origin/sarich/tao-pounders-add-corr-test
  origin/sarich/tao-separate-state-design
  origin/sarich/vi/snes-aug-example
  origin/sarich/xsdk-add-test-arch
  origin/shri/FTRTDS-project
  origin/shri/ts-dae-semi-explicit
  origin/shri/ts-powergrid
  origin/stefano_zampini/dmplex-matis-support
  origin/stefano_zampini/feature-pcbddc-saddlepoint
  origin/stefano_zampini/fix-coherent-computation-constraints
  origin/stefano_zampini/hypre-ams-zerointerior-feature
  origin/stefano_zampini/new-elemental-interface
  origin/stefano_zampini/pcbddc-multilevel-extensions
  origin/tisaac/buildsystem-feature-parallel
  origin/tisaac/buildsystem-feature-subst-link-flags
  origin/tisaac/config-fix-petsc-py
  origin/tisaac/dmp4est-feature-mapped-coordinates
  origin/tisaac/dual-space-get-traces
  origin/tisaac/feature-gamg-compose-graph
  origin/tisaac/feature-plex-example-nonconforming
  origin/tisaac/feature-seqaij-get-submat-row-unordered
  origin/tisaac/feature-seqaij-submat-col-unsorted
  origin/tisaac/fix-ex3-coords
  origin/tisaac/fix-gamg-set-coordinates
  origin/tisaac/gamg-more-info
  origin/tisaac/knepley/feature-composable-callbacks
  origin/tisaac/ksp-fix-cheby-pc-handling
  origin/tisaac/pc-pbjacobi-vec-get-array-read
  origin/tisaac/petsc-next-upstream
  origin/tisaac/warn-next-upstream
  origin/vi/snes-newtonaugas
