[petsc-dev] git repo branches housekeeping
Tue Jun 9 20:23:26 CDT 2015
I've deleted all deveopment branches that are already merged into
maint (v3.6) from https://bitbucket.org/petsc/petsc
However if you wish to remove these branches from your clone - it has
to be done manually (in each clone).
To get this list of branches to delete - you can do:
git branch --merged v3.6 |egrep -v " (maint|master|next)" > branches_to_delete
After *verifying* the list is correct - and ok to delete - they can be deleted with:
git branch -d `cat branches_to_delete`
And to sync the [deleted] remove branch list info - you can do:
git fetch
git remote prune origin
For more housekeeping - look at the remaining local and remote
branches and figure-out what to do. [perhaps some of them are
intermediate branches during rebase - or abandoned features that
should be deleted]. For my branches - I would do:
git branch
git branch -r |grep balay
Satish
reference for self:
$ git branch -r --merged v3.6 |egrep  -v origin/\(maint\|master\|next\) > remote_branches_to_delete
<edit 'remote_branches_to_delete' and change 'origin/foobar' to ':foobar'>
$ git push -u origin `cat remote_branches_to_delete`
To git at bitbucket.org:petsc/petsc.git
 - [deleted]         balay/add-clean
 - [deleted]         balay/add-f2003-derived-class-ex
 - [deleted]         balay/atpesc-tutorial-2014
 - [deleted]         balay/build-pkgs-without-wall
 - [deleted]         balay/enable-cygwin-threads
 - [deleted]         balay/fix-ISConcatenate-memleak
 - [deleted]         balay/fix-baij-dup-proto
 - [deleted]         balay/fix-batch-sdot
 - [deleted]         balay/fix-chaco-blas-test
 - [deleted]         balay/fix-ctetgen-build
 - [deleted]         balay/fix-ctetgen-downloadURLSetByUser
 - [deleted]         balay/fix-glibc-2.20_DEFAULT_SOURCE
 - [deleted]         balay/fix-missing-proto-test
 - [deleted]         balay/fix-moab-optionalpkgs
 - [deleted]         balay/fix-openmpi-sf
 - [deleted]         balay/fix-scalapack-to-use-f2cblas
 - [deleted]         balay/fix-suitesparse-32bit-bug
 - [deleted]         balay/fix-win-f2c-mdd
 - [deleted]         balay/split-mpi4py-build-log
 - [deleted]         balay/superlu_dist_4.0
 - [deleted]         balay/update-Elemental-0.85
 - [deleted]         balay/update-SuiteSparse-4.4.3
 - [deleted]         balay/update-configure-lib-search
 - [deleted]         balay/update-etags
 - [deleted]         balay/update-git-checks
 - [deleted]         balay/update-gnumake-check
 - [deleted]         balay/update-hdf5
 - [deleted]         balay/update-hypre-2.10.0b
 - [deleted]         balay/update-mpich-3.1.3
 - [deleted]         balay/update-pastix_5.2.2.20
 - [deleted]         balay/update-petsc4py-test
 - [deleted]         balay/update-scotch_6.0.3-new
 - [deleted]         barry/add-casts-for-suitsparse-64bitindices
 - [deleted]         barry/add-ksp-total-iterations/master
 - [deleted]         barry/add-snes-monitor-ksp
 - [deleted]         barry/add-some-matsolveforward-back
 - [deleted]         barry/add-timeout-nag
 - [deleted]         barry/allow-nonsquare-schurcomplement
 - [deleted]         barry/allow-null-vecsetvalues
 - [deleted]         barry/always-include-complex
 - [deleted]         barry/asmunder/DMDA-fortran-example
 - [deleted]         barry/change-ilu-default-shift
 - [deleted]         barry/changes-mpipy-handle-mpifh
 - [deleted]         barry/check-cuda-compiler-only-when-needed
 - [deleted]         barry/check-mpi-include
 - [deleted]         barry/clarify-readVecMatIS-PetscBinaryIO
 - [deleted]         barry/clean-gamg
 - [deleted]         barry/cleanup-blaslapack
 - [deleted]         barry/docs-matblocksize
 - [deleted]         barry/download-trilinos
 - [deleted]         barry/dynamic-matsolverpackageregister
 - [deleted]         barry/error-on-64bitindices-with-ml
 - [deleted]         barry/error-print-options
 - [deleted]         barry/erroronbaddmlocaltoglobal_da
 - [deleted]         barry/experiment
 - [deleted]         barry/feature-bargraph
 - [deleted]         barry/feature-configure-allow-environment-vars
 - [deleted]         barry/feature-hdf5-flexible-initial-dimension
 - [deleted]         barry/feature-http-in-manualpages
 - [deleted]         barry/feature-vec-lock
 - [deleted]         barry/fix-MatLoad_MPIDense_DenseInFile
 - [deleted]         barry/fix-apple-install
 - [deleted]         barry/fix-ascii-vtk-output
 - [deleted]         barry/fix-bjacobi-vector-lengths
 - [deleted]         barry/fix-complex-petscmath
 - [deleted]         barry/fix-damp-not-one-pcapplyrichardson
 - [deleted]         barry/fix-directory-layout
 - [deleted]         barry/fix-dmda-1d-mirror
 - [deleted]         barry/fix-dmda-creatematrix-large-nc
 - [deleted]         barry/fix-dmlocaltoglobal-insert
 - [deleted]         barry/fix-dmrestorexxvector
 - [deleted]         barry/fix-fortran-log-flops
 - [deleted]         barry/fix-fortran-pcfieldsplitsetis
 - [deleted]         barry/fix-ftn-custom-continuation
 - [deleted]         barry/fix-gamg-preallocation-block
 - [deleted]         barry/fix-getvecs
 - [deleted]         barry/fix-git-in-configure
 - [deleted]         barry/fix-hdf5
 - [deleted]         barry/fix-hdf5-complex
 - [deleted]         barry/fix-inserting-new-nonzero-column-location
 - [deleted]         barry/fix-install-bindirectory
 - [deleted]         barry/fix-ios
 - [deleted]         barry/fix-islocaltoglobalmappingcreateis-with-blocksize
 - [deleted]         barry/fix-isltogmappingapplybs
 - [deleted]         barry/fix-ksp-fcg
 - [deleted]         barry/fix-ksp-fcg-trunction-type
 - [deleted]         barry/fix-kspgetvecs-with-dmshell
 - [deleted]         barry/fix-matdiagonalset
 - [deleted]         barry/fix-matgetdiagonalblock
 - [deleted]         barry/fix-matgetrowmax-fortran
 - [deleted]         barry/fix-matload-mpidense-denseinfile
 - [deleted]         barry/fix-matload-uneven-rows
 - [deleted]         barry/fix-matmultadd-shell
 - [deleted]         barry/fix-matsetsize-matload
 - [deleted]         barry/fix-matsettype-cleanup/master
 - [deleted]         barry/fix-memoryallocation-matsor-seqbaij
 - [deleted]         barry/fix-mg-interpolate-provided
 - [deleted]         barry/fix-module
 - [deleted]         barry/fix-monitorlg
 - [deleted]         barry/fix-options-default
 - [deleted]         barry/fix-pc-reuse-preconditioner-bjacobi
 - [deleted]         barry/fix-petsc-objects-log
 - [deleted]         barry/fix-petsc4py-py
 - [deleted]         barry/fix-petscobjectviewfromoptions
 - [deleted]         barry/fix-prefix-installs
 - [deleted]         barry/fix-sdot-handling
 - [deleted]         barry/fix-setters
 - [deleted]         barry/fix-tao-petsc-c-begin
 - [deleted]         barry/fix-usage-with-mpidatatypenull
 - [deleted]         barry/fix-valgrind
 - [deleted]         barry/fix-vecload-group-handling
 - [deleted]         barry/hwloc
 - [deleted]         barry/improve-afterimage
 - [deleted]         barry/improve-nullspace-handling
 - [deleted]         barry/improve-pcamgcreategraph
 - [deleted]         barry/mv-tao-cpcg-kspcreate
 - [deleted]         barry/namespace-install
 - [deleted]         barry/no-warning-for-overwritten-environmental-variable
 - [deleted]         barry/objects-dump
 - [deleted]         barry/optimize-dmlocaltolocal_da
 - [deleted]         barry/optimize-matdiagonalset
 - [deleted]         barry/optimize-matshift
 - [deleted]         barry/patch-flopcounts
 - [deleted]         barry/petsc-sa-refactor-rebase
 - [deleted]         barry/petscobjectviewfromoptions-resetincall
 - [deleted]         barry/propagate-pcsetup-failures
 - [deleted]         barry/refactor-petscsubcomm
 - [deleted]         barry/remove-dreal
 - [deleted]         barry/remove-sidl
 - [deleted]         barry/remove-thread-classes-master
 - [deleted]         barry/remove-unneeded-paren-petscmalloc
 - [deleted]         barry/reuse-hwloc
 - [deleted]         barry/rm-dead-code
 - [deleted]         barry/sarich/feature-jenkins-submit
 - [deleted]         barry/saws-options
 - [deleted]         barry/saws-options-merge-master
 - [deleted]         barry/snes-monitor-vi-residual
 - [deleted]         barry/stefano_zampini/dmda-changeaotype
 - [deleted]         barry/swift-example
 - [deleted]         barry/test-trilinos-superlu
 - [deleted]         barry/threadsafety-kspconvergedreason-kspmonitor
 - [deleted]         barry/update-developers-manual-petsc-maint
 - [deleted]         barry/update-sowing
 - [deleted]         barry/update-suitesparse-version
 - [deleted]         barry/use-ksp_matmult_pcapply-in-ksp-methods
 - [deleted]         dave-may/mat-fixes
 - [deleted]         dmeiser/adding-vtable-vecscatter
 - [deleted]         dmeiser/fix-scatterinitcusp
 - [deleted]         dmeiser/pullrequest-fix-PetscOptionsEnum
 - [deleted]         dmeiser/pullrequest-fix-PetscOptionsEnum2
 - [deleted]         dmeiser/pullrequest-fix-cusp-bjacobi2
 - [deleted]         dmeiser/pullrequest-fix-dmda-cusparse
 - [deleted]         dmeiser/pullrequest-fix-format-specifier-ex43
 - [deleted]         dmeiser/pullrequest-remove-thrust-py
 - [deleted]         dnystrom/vecsetoptionsprefix-fortran
 - [deleted]         emil/fix-ts-dae-rebased-v3
 - [deleted]         hongzh/add-costintegral-ts-rk-adjoint
 - [deleted]         hongzh/fix-ts-power-grid-ex9opt
 - [deleted]         hongzh/fix-ts-rk
 - [deleted]         hongzh/fix-ts-theta-and-ex20adj
 - [deleted]         hongzh/fix-ts-trajectory
 - [deleted]         hongzh/petsc-sa-cleanup
 - [deleted]         hzhang/add-OptionsScalarArray
 - [deleted]         hzhang/cleanup-mpiptap
 - [deleted]         hzhang/elemental-matconvert
 - [deleted]         hzhang/elemental-matconvertnew
 - [deleted]         hzhang/ex-update
 - [deleted]         hzhang/fix-blame
 - [deleted]         hzhang/fix-lsqr
 - [deleted]         hzhang/fix-matgetdiagonal-errflag
 - [deleted]         hzhang/fix-mpiptap
 - [deleted]         hzhang/fix-subcommsettype
 - [deleted]         hzhang/fix-vecsquare
 - [deleted]         hzhang/ksp-addtest
 - [deleted]         hzhang/ksp-ex39
 - [deleted]         hzhang/ksp-ex52
 - [deleted]         hzhang/mat-redundant_sbaij
 - [deleted]         hzhang/mataxpy-bugfix
 - [deleted]         hzhang/mataxpy-subset
 - [deleted]         hzhang/mataxpy-subset-sbaij
 - [deleted]         hzhang/mataxpy-subsetcleanup
 - [deleted]         hzhang/matgetrowij-bugfix
 - [deleted]         hzhang/matgetsubmat_sbaij
 - [deleted]         hzhang/matmatmult-bugfix
 - [deleted]         hzhang/mumps-bugfix
 - [deleted]         hzhang/mumps-fix-convertToTriples
 - [deleted]         hzhang/update-MUMPS_5.0.0
 - [deleted]         icl/lawrence/dmplex-1d-refinement
 - [deleted]         irving/hollow
 - [deleted]         jed/chem
 - [deleted]         jed/config-env-paths
 - [deleted]         jed/config-re.sub
 - [deleted]         jed/doc-fixes
 - [deleted]         jed/fix-checkpointer-char
 - [deleted]         jed/ksp-explicit-operator-BAorAB
 - [deleted]         jed/matzerorows-nocomm
 - [deleted]         jed/vecview-native
 - [deleted]         jose/mpidense-with-array
 - [deleted]         jose/split-reduction
 - [deleted]         jose/upgrade-cusp-0.5.1
 - [deleted]         karlrupp/feature-gpu-handle-access-for-vec
 - [deleted]         karlrupp/feature-viennacl-1.6.1
 - [deleted]         karlrupp/feature-viennacl-1.6.2
 - [deleted]         karlrupp/fix-aijviennacl-destruction
 - [deleted]         karlrupp/fix-cuda6-configuration
 - [deleted]         karlrupp/fix-cusp-vecmdot-local-size-0
 - [deleted]         karlrupp/remove-PETSC_HAVE_CUSP_SMOOTHED_AGGREGATION
 - [deleted]         karpeev/fix-mat-getschurcomplement
 - [deleted]         karpeev/fix-mat-getsubmatrices-mpi
 - [deleted]         karpeev/ksp-pcgasm-overhaul
 - [deleted]         karpeev/maint/fix-petscmath-missing-atan2
 - [deleted]         knepley/doc-snes
 - [deleted]         knepley/doc-webpage-prizes
 - [deleted]         knepley/feature-combined-tabulation
 - [deleted]         knepley/feature-composable-callbacks
 - [deleted]         knepley/feature-dm-dimension-handling
 - [deleted]         knepley/feature-dm-sf-local-copy
 - [deleted]         knepley/feature-dmts-check
 - [deleted]         knepley/feature-ds-fortran-example
 - [deleted]         knepley/feature-fe-fv-hybrid
 - [deleted]         knepley/feature-harmonic-advection
 - [deleted]         knepley/feature-p4est-download
 - [deleted]         knepley/feature-parallel-configure
 - [deleted]         knepley/feature-parallel-partition
 - [deleted]         knepley/feature-partitioner-simple
 - [deleted]         knepley/feature-pc-local-msm
 - [deleted]         knepley/feature-perf-api
 - [deleted]         knepley/feature-plex-assembly-cellrange
 - [deleted]         knepley/feature-plex-assembly-fortran
 - [deleted]         knepley/feature-plex-bc
 - [deleted]         knepley/feature-plex-generator-args
 - [deleted]         knepley/feature-plex-label-output
 - [deleted]         knepley/feature-plex-partitioner-shell
 - [deleted]         knepley/feature-quadrature-fortran
 - [deleted]         knepley/feature-remove-config-init
 - [deleted]         knepley/feature-ts-fem+fvm-example
 - [deleted]         knepley/feature-viewer-partial-read
 - [deleted]         knepley/fix-callback-coordinate-dim
 - [deleted]         knepley/fix-cohesive-intersection
 - [deleted]         knepley/fix-compiler-warnings
 - [deleted]         knepley/fix-config-tmpdir-perm
 - [deleted]         knepley/fix-configure-cmake
 - [deleted]         knepley/fix-configure-mpi-version
 - [deleted]         knepley/fix-configure-package-check
 - [deleted]         knepley/fix-configure-petsc-dep
 - [deleted]         knepley/fix-configure-program-errors
 - [deleted]         knepley/fix-dm-composition
 - [deleted]         knepley/fix-dm-default-section-null
 - [deleted]         knepley/fix-dm-df-local-copy
 - [deleted]         knepley/fix-dm-subdm
 - [deleted]         knepley/fix-dmload-parallel
 - [deleted]         knepley/fix-ds-tab-fortran
 - [deleted]         knepley/fix-dtfe-allow-null-residual-func
 - [deleted]         knepley/fix-fas-cleanup
 - [deleted]         knepley/fix-fft-fortran
 - [deleted]         knepley/fix-fieldsplit-mg
 - [deleted]         knepley/fix-fortran-stubs
 - [deleted]         knepley/fix-iscoloring-create
 - [deleted]         knepley/fix-l2g-checks
 - [deleted]         knepley/fix-label-distribute
 - [deleted]         knepley/fix-label-leak
 - [deleted]         knepley/fix-log2
 - [deleted]         knepley/fix-manual-mat-options
 - [deleted]         knepley/fix-mat-view-bs
 - [deleted]         knepley/fix-mpiio-flag
 - [deleted]         knepley/fix-pc-fieldsplit-fortran
 - [deleted]         knepley/fix-petsc-fv
 - [deleted]         knepley/fix-plex-1d-refinement
 - [deleted]         knepley/fix-plex-cgns-bc
 - [deleted]         knepley/fix-plex-coords-parallel
 - [deleted]         knepley/fix-plex-distribute-uninterpolated
 - [deleted]         knepley/fix-plex-ex3-constraints
 - [deleted]         knepley/fix-plex-examples-refinement
 - [deleted]         knepley/fix-plex-f90
 - [deleted]         knepley/fix-plex-geom
 - [deleted]         knepley/fix-plex-global-offset
 - [deleted]         knepley/fix-plex-gmsh-64int
 - [deleted]         knepley/fix-plex-latex
 - [deleted]         knepley/fix-plex-offset-calc
 - [deleted]         knepley/fix-plex-orient
 - [deleted]         knepley/fix-plex-orient-1d
 - [deleted]         knepley/fix-plex-refine-check
 - [deleted]         knepley/fix-plex-refine-sf
 - [deleted]         knepley/fix-plex-refinement-check
 - [deleted]         knepley/fix-plex-snes-examples
 - [deleted]         knepley/fix-plex-submesh-intersection
 - [deleted]         knepley/fix-plex-submesh-section
 - [deleted]         knepley/fix-plex-tests
 - [deleted]         knepley/fix-plex-tetgen
 - [deleted]         knepley/fix-plex-xdmf
 - [deleted]         knepley/fix-snesew-postsolve
 - [deleted]         knepley/fix-snesvi-types
 - [deleted]         knepley/fix-submesh-crossedge
 - [deleted]         knepley/fix-vec-init
 - [deleted]         knepley/fix-vec-readonly
 - [deleted]         knepley/fix-veclock-fftw
 - [deleted]         knepley/fortran-plex-fromfile
 - [deleted]         knepley/mat-find-zero-diagonals
 - [deleted]         knepley/plex-uninterpolate-sf
 - [deleted]         knepley/solkx
 - [deleted]         knepley/zoltan-update
 - [deleted]         lawrence/dmplex-1d-refinement
 - [deleted]         mark/ex49-bs
 - [deleted]         mark/fortanenums
 - [deleted]         mark/gamg-crs-ksp2
 - [deleted]         mark/gamg-remove-eig-est
 - [deleted]         mark/gamg-serial
 - [deleted]         mark/gamg-square
 - [deleted]         mark/gamgdoc
 - [deleted]         mark/ksp-zero-eig
 - [deleted]         mark/matnestmatconvert
 - [deleted]         mlange/feature-parallel-distribute
 - [deleted]         mlange/feature-plex-fluent
 - [deleted]         mlange/feature-plex-gmsh-fortran
 - [deleted]         mlange/fix-plex-distribute-perf-logging
 - [deleted]         mlange/fix-plex-distributed-refine
 - [deleted]         mlange/fix-plex-gmsh-binary-groups
 - [deleted]         mlange/plex-gmsh-binary
 - [deleted]         mlange/refactor-plex-distribute
 - [deleted]         pefarrell/linesearch-nleqerr
 - [deleted]         placasse/VecGetSubVector
 - [deleted]         pr148/qulogic/python-binaryio-defaults
 - [deleted]         pr227/iaannn/fix-matlab-write-bin-complex
 - [deleted]         pr232/pefarrell/snes-has-npc
 - [deleted]         pr234/vasiliy_kozyrev/mkl_cpardiso
 - [deleted]         pr235/vijaysm/dmmoab-complex
 - [deleted]         pr239/jeguyer/fix-matrix-market-export
 - [deleted]         pr244/pefarrell/linesearch-nleqerr
 - [deleted]         pr245/mapdes/dmcreateinjection-mat
 - [deleted]         pr248/dmeiser/fix-VecGetLocalVector
 - [deleted]         pr252/dmay/PetscViewerBinarySkipHeaderVecViewLoad
 - [deleted]         pr252/dmay/PetscViewerBinarySkipHeaderVecViewLoad-maint
 - [deleted]         pr258/dmay/dmay/PetscViewerBinaryRefactor/master
 - [deleted]         pr259/dmay/dmay/BinaryViewerTestBugfixes/maint
 - [deleted]         pr270/knepley/dm-set-sf-options/master
 - [deleted]         pr276/elbueler/fix-ex9/master
 - [deleted]         pr277/pefarrell/pefarrell/fieldsplit-is-block-size/master
 - [deleted]         pr291/andrewspott/andrewspott/MatCreateHTranspose/master
 - [deleted]         pr296/hakostra/HDF5-VecLoad-BS-fix/master
 - [deleted]         pr298/semihozmen/semihozmen/ksp-fcg-eigen-comp-support/master
 - [deleted]         pr306/pefarrell/pefarrell/snes-composite-vi-fixes/master
 - [deleted]         pr311/PascalTremblay/PascalTremblay/mkl_pardiso_support_sbaij/master
 - [deleted]         pr317/shanestafford/maint/fix-mat-disassemble-nonzerostate
 - [deleted]         psanan/doc-typos
 - [deleted]         psanan/ksp-ex43-update
 - [deleted]         psanan/ksp-fcg
 - [deleted]         psanan/logview-bugfix
 - [deleted]         sarich/feature-configure-xsdk
 - [deleted]         sarich/feature-jenkins-submit
 - [deleted]         sarich/feature-tao-iteration-count
 - [deleted]         sarich/fix-lmvm-warning
 - [deleted]         sarich/fix-pounders-initial-monitor
 - [deleted]         sarich/fix-print-statement
 - [deleted]         sarich/fix-tao-default-options-guards
 - [deleted]         sarich/fix-tao-jbearing-bqpip
 - [deleted]         sarich/fix-tao-lcl_h-include
 - [deleted]         sarich/fix-tao-linesearch-reset
 - [deleted]         sarich/fix-tao-pounders-repeating
 - [deleted]         sarich/fix-vecmedian-restore
 - [deleted]         sarich/tao-add-fortran-stubs
 - [deleted]         sarich/tao-examples-remove-double-delimiter
 - [deleted]         sarich/tao-get-number-ksp-its
 - [deleted]         sarich/tao-history-store-ksp-its
 - [deleted]         sarich/tao-ksp-its
 - [deleted]         shri/adjoints-and-events
 - [deleted]         shri/clone-dmnetwork
 - [deleted]         shri/dmplex-add-mat-localtoglobalmapping
 - [deleted]         shri/fix-tsevent
 - [deleted]         shri/ts-is-for-differential-variables
 - [deleted]         stefano_zampini/fix-64bit-indices
 - [deleted]         stefano_zampini/fix-coherent-computation-constraints-nocomm
 - [deleted]         stefano_zampini/fix-deluxe-solver-inheritance
 - [deleted]         stefano_zampini/fix-dirichlet-trick
 - [deleted]         stefano_zampini/fix-feti-rhs
 - [deleted]         stefano_zampini/fix-pcis-bug-after-setfromoptions
 - [deleted]         stefano_zampini/fix-typo-dofsplit
 - [deleted]         stefano_zampini/fix-uninitialized-ex59
 - [deleted]         stefano_zampini/fixes
 - [deleted]         stefano_zampini/fixes-and-improvements-multilevel
 - [deleted]         stefano_zampini/fixes-for-raviart-thomas
 - [deleted]         stefano_zampini/get-rid-of-PCBDDCApplySchur
 - [deleted]         stefano_zampini/hypre-ads
 - [deleted]         stefano_zampini/hypre-ams
 - [deleted]         stefano_zampini/matbaij-fixgetsubmatrix
 - [deleted]         stefano_zampini/matis-preallocation
 - [deleted]         stefano_zampini/matis_getmpixaij
 - [deleted]         stefano_zampini/matmumps-schursupport
 - [deleted]         stefano_zampini/matschur_transpose
 - [deleted]         stefano_zampini/mattransposedense-ldafix
 - [deleted]         stefano_zampini/pcbddc-adaptive-selection
 - [deleted]         stefano_zampini/pcbddc-changeofbasis
 - [deleted]         stefano_zampini/pcbddc-fix-matgetvecs
 - [deleted]         stefano_zampini/pcbddc-fix-mpi-op-typo
 - [deleted]         stefano_zampini/pcbddc-primalfixes
 - [deleted]         stefano_zampini/pcbddc_deluxe
 - [deleted]         stefano_zampini/pcbddcgraph-improve
 - [deleted]         stefano_zampini/seqaijtodense
 - [deleted]         tisaac/config-log-integer-size
 - [deleted]         tisaac/dm-dim-embed-auto
 - [deleted]         tisaac/dm-fe-tensor-in-header
 - [deleted]         tisaac/dm-plex-fix-nonconforming
 - [deleted]         tisaac/feature-fe-geom-dim
 - [deleted]         tisaac/feature-gamg-extensible
 - [deleted]         tisaac/feature-gamg-save-perm
 - [deleted]         tisaac/fix-chaco-triangle-64bit
 - [deleted]         tisaac/fix-ctetgen-make
 - [deleted]         tisaac/fix-gamg-square-graph
 - [deleted]         tisaac/fix-makefile-allgtags
 - [deleted]         tisaac/fix-sf-nroots-nleaves-switch
 - [deleted]         tisaac/fix-snes-ex48-cleanup
 - [deleted]         tisaac/fix-solaris-compiler-regexp
 - [deleted]         tisaac/ksp-cheby-update-tests
 - [deleted]         tisaac/ksp-cheby-use-mat-state
 - [deleted]         tisaac/mat-get-submatrix-unordered
 - [deleted]         tisaac/pc-pbjacobi-fix-get-array-read
 - [deleted]         tisaac/plex-fix-ex3-num-comp
 - [deleted]         tisaac/plex-fix-warnings
 - [deleted]         tisaac/plex-flexible-projection
 - [deleted]         tisaac/simplify-register-all
 - [deleted]         tisaac/thplex
 - [deleted]         xolotl
