[petsc-dev] [SLEPc] For users of PETSc master branch, API change
Leoni, Massimiliano Massimiliano.Leoni at Rolls-Royce.com
Tue Nov 10 03:19:03 CST 2015
I thought I did, really :D
Apparently I didn't realise I was on another PETSc branch, whereas I thought I was pulling from master.
It works now, thanks!
Massimiliano
> -----Original Message-----
> From: Jose E. Roman [mailto:jroman at dsic.upv.es]
> Sent: 10 November 2015 09:07
> To: Leoni, Massimiliano
> Cc: petsc-dev
> Subject: Re: [petsc-dev] [SLEPc] For users of PETSc master branch, API
> change
> It seems that you are compiling against the old PETSc. You have to update
> both PETSc and SLEPc.
> Jose
> > El 10/11/2015, a las 10:04, Leoni, Massimiliano <Massimiliano.Leoni at rolls-
> royce.com> escribió:
> > Jose, I see the commit but I still get a compilation error.
> > I attach the logs. It looks like there is a definition that was not updated.
> > Best,
> > Massimiliano
> >> Sent: 09 November 2015 14:48
> >> To: petsc-users
> >> Cc: Leoni, Massimiliano; petsc-dev
> >> API change
> >> The fix is already in SLEPc's branches 'jose/sync-with-petsc' and 'next'.
> >> Will merge into 'master' tomorrow.
> >> Jose
> >>> El 9/11/2015, a las 15:44, Satish Balay <balay at mcs.anl.gov> escribió:
> >>> you can try using a slightly older 'master' snapshot' [until you get
> >>> the slpec fix]
> >>> For eg:
> >>> git checkout d916695f21d798ebdf80dc439ef54c5223c9183c
> >>> And once the slepc fix is available - you can do:
> >>> git checkout master
> >>> git pull
> >>> Satish
> >>> On Mon, 9 Nov 2015, Leoni, Massimiliano wrote:
> >>>> Ok, sorry!
> >>>> It looks like I chose the worst possible day to update :D
> >>>> Best,
> >>>> Massimiliano
> >>>>> Sent: 09 November 2015 14:26
> >>>>> Cc: Barry Smith; PETSc; petsc-dev
> >>>>> API change
> >>>>> Working on it. Be patient. Should be available on master tomorrow.
> >>>>> Jose
> >>>>>> El 9/11/2015, a las 15:23, Leoni, Massimiliano
> >>>>>> <Massimiliano.Leoni at Rolls-
> >>>>> Royce.com> escribió:
> >>>>>> Is there a branch in the SLEPc repo that supports this?
> >>>>>> Massimiliano
> >>>>>>> From: petsc-dev-bounces at mcs.anl.gov [mailto:petsc-dev-
> >>>>>>> bounces at mcs.anl.gov] On Behalf Of Barry Smith
> >>>>>>> Sent: 09 November 2015 00:21
> >>>>>>> To: PETSc; petsc-dev
> >>>>>>> Subject: [petsc-dev] For users of PETSc master branch, API
> >>>>>>> change
> >>>>>>> For users of the PETSc master branch.
> >>>>>>> I have pushed into master some API changes for the
> >>>>>>> PetscOptionsGetXXX() and related routines. The first argument is
> >>>>>>> now a PetscOptions object, which is optional, if you pass a NULL
> >>>>>>> in for the first argument (or a PETSC_NULL_OBJECT in Fortran)
> >>>>>>> you will retain the same functionality as you had previously.
> >>>>>>> Barry
> >>>>>> The data contained in, or attached to, this e-mail, may contain
> >>>>>> confidential
> >>>>> information. If you have received it in error you should notify
> >>>>> the sender immediately by reply e-mail, delete the message from
> >>>>> your system and contact +44 (0) 3301235850 (Security Operations
> >>>>> Centre) if you need assistance. Please do not copy it for any
> >>>>> purpose, or disclose its contents to any other person.
> >>>>>> An e-mail response to this address may be subject to interception
> >>>>>> or
> >>>>> monitoring for operational reasons or for lawful business practices.
> >>>>>> (c) 2015 Rolls-Royce plc
> >>>>>> Registered office: 62 Buckingham Gate, London SW1E 6AT Company
> >>>>> number: 1003142. Registered in England.
> >>>> confidential
> >> information. If you have received it in error you should notify the
> >> sender immediately by reply e-mail, delete the message from your
> >> system and contact +44 (0) 3301235850 (Security Operations Centre) if
> >> you need assistance. Please do not copy it for any purpose, or
> >>>> or
> > The data contained in, or attached to, this e-mail, may contain confidential
> information. If you have received it in error you should notify the sender
> immediately by reply e-mail, delete the message from your system and
> contact +44 (0) 3301235850 (Security Operations Centre) if you need
> assistance. Please do not copy it for any purpose, or disclose its contents to
> any other person.
> > An e-mail response to this address may be subject to interception or
> > <configure.log><make.log>
The data contained in, or attached to, this e-mail, may contain confidential information. If you have received it in error you should notify the sender immediately by reply e-mail, delete the message from your system and contact +44 (0) 3301235850 (Security Operations Centre) if you need assistance. Please do not copy it for any purpose, or disclose its contents to any other person.
An e-mail response to this address may be subject to interception or monitoring for operational reasons or for lawful business practices.
Registered office: 62 Buckingham Gate, London SW1E 6AT Company number: 1003142. Registered in England.
