[petsc-dev] [SLEPc] For users of PETSc master branch, API change
Jose E. Roman jroman at dsic.upv.es
Tue Nov 10 03:07:07 CST 2015
It seems that you are compiling against the old PETSc. You have to update both PETSc and SLEPc.
Jose
> El 10/11/2015, a las 10:04, Leoni, Massimiliano <Massimiliano.Leoni at rolls-royce.com> escribió:
> Jose, I see the commit but I still get a compilation error.
> I attach the logs. It looks like there is a definition that was not updated.
> Best,
> Massimiliano
>> -----Original Message-----
>> From: Jose E. Roman [mailto:jroman at dsic.upv.es]
>> Sent: 09 November 2015 14:48
>> To: petsc-users
>> Cc: Leoni, Massimiliano; petsc-dev
>> Subject: Re: [petsc-dev] [SLEPc] For users of PETSc master branch, API
>> change
>> The fix is already in SLEPc's branches 'jose/sync-with-petsc' and 'next'.
>> Will merge into 'master' tomorrow.
>> Jose
>>> El 9/11/2015, a las 15:44, Satish Balay <balay at mcs.anl.gov> escribió:
>>> you can try using a slightly older 'master' snapshot' [until you get
>>> the slpec fix]
>>> For eg:
>>> git checkout d916695f21d798ebdf80dc439ef54c5223c9183c
>>> And once the slepc fix is available - you can do:
>>> git checkout master
>>> git pull
>>> Satish
>>> On Mon, 9 Nov 2015, Leoni, Massimiliano wrote:
>>>> Ok, sorry!
>>>> It looks like I chose the worst possible day to update :D
>>>> Best,
>>>> Massimiliano
>>>>> Sent: 09 November 2015 14:26
>>>>> To: Leoni, Massimiliano
>>>>> Cc: Barry Smith; PETSc; petsc-dev
>>>>> API change
>>>>> Working on it. Be patient. Should be available on master tomorrow.
>>>>> Jose
>>>>>> El 9/11/2015, a las 15:23, Leoni, Massimiliano
>>>>>> <Massimiliano.Leoni at Rolls-
>>>>> Royce.com> escribió:
>>>>>> Is there a branch in the SLEPc repo that supports this?
>>>>>> Massimiliano
>>>>>>> From: petsc-dev-bounces at mcs.anl.gov [mailto:petsc-dev-
>>>>>>> bounces at mcs.anl.gov] On Behalf Of Barry Smith
>>>>>>> Sent: 09 November 2015 00:21
>>>>>>> To: PETSc; petsc-dev
>>>>>>> Subject: [petsc-dev] For users of PETSc master branch, API change
>>>>>>> For users of the PETSc master branch.
>>>>>>> I have pushed into master some API changes for the
>>>>>>> PetscOptionsGetXXX() and related routines. The first argument is
>>>>>>> now a PetscOptions object, which is optional, if you pass a NULL
>>>>>>> in for the first argument (or a PETSC_NULL_OBJECT in Fortran) you
>>>>>>> will retain the same functionality as you had previously.
>>>>>>> Barry
>>>>>> The data contained in, or attached to, this e-mail, may contain
>>>>>> confidential
>>>>> information. If you have received it in error you should notify the
>>>>> sender immediately by reply e-mail, delete the message from your
>>>>> system and contact +44 (0) 3301235850 (Security Operations Centre)
>>>>> if you need assistance. Please do not copy it for any purpose, or
>>>>> disclose its contents to any other person.
>>>>>> An e-mail response to this address may be subject to interception
>>>>>> or
>>>>> monitoring for operational reasons or for lawful business practices.
>>>>>> (c) 2015 Rolls-Royce plc
>>>>>> Registered office: 62 Buckingham Gate, London SW1E 6AT Company
>>>>> number: 1003142. Registered in England.
>>>> The data contained in, or attached to, this e-mail, may contain confidential
>> information. If you have received it in error you should notify the sender
>> immediately by reply e-mail, delete the message from your system and
>> contact +44 (0) 3301235850 (Security Operations Centre) if you need
>> assistance. Please do not copy it for any purpose, or disclose its contents to
>> any other person.
>>>> An e-mail response to this address may be subject to interception or
> The data contained in, or attached to, this e-mail, may contain confidential information. If you have received it in error you should notify the sender immediately by reply e-mail, delete the message from your system and contact +44 (0) 3301235850 (Security Operations Centre) if you need assistance. Please do not copy it for any purpose, or disclose its contents to any other person.
> An e-mail response to this address may be subject to interception or monitoring for operational reasons or for lawful business practices.
> Registered office: 62 Buckingham Gate, London SW1E 6AT Company number: 1003142. Registered in England.
> <configure.log><make.log>
