[petsc-dev] Fwd: [petsc-users] configure error on Titan with Intel
Mark Adams mfadams at lbl.gov
Thu May 14 08:39:34 CDT 2015
We have Titan working but we have a problem that we need lstdc++ to get
PETSc to configure.  Otherwise it fails to build fortran.  This seems to
only be needed for GNU.  This is for PGI.  If we remove this C++ works,
otherwise there is a missing external.  I guess I can just deploy two
version, on for fortran and one for C++ (I have a C++ and a fortran code
that I support).
On Tue, May 12, 2015 at 9:36 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Remind me again how much the US tax payers spend on this machine each
> year.
> Begin forwarded message:
> *From: *Mark Adams <mfadams at lbl.gov>
> *Subject: **Re: [petsc-users] configure error on Titan with Intel*
> *Date: *May 12, 2015 at 11:12:55 AM CDT
> *To: *Barry Smith <bsmith at mcs.anl.gov>
> *Cc: *Jed Brown <jed at jedbrown.org>, petsc-users <petsc-users at mcs.anl.gov>,
> "David Trebotich" <treb at lbl.gov>, "D'Azevedo, Ed F." <dazevedoef at ornl.gov>
>>   Notes: ./configure ran fine and detected -lhwloc in some standard
>> system install location under normal circumstances it couldn't just
>> disappear for a different example.
> I configured in an interactive shell, so on a compute node.  I tried to
> 'make ex56' on a login node, as usual.  So I am guessing that it would have
> worked if I had made it a compute node.  They have an inconstancy, I'm
> guessing. I can try it all on a compute node ....
> Mark
>> > On Fri, May 8, 2015 at 5:51 PM, Jed Brown <jed at jedbrown.org> wrote:
>> > Satish Balay <balay at mcs.anl.gov> writes:
>> > > Also - Perhaps with intel compilers - the recommended blas is
>> > > something other than ACML? [like MKL?]. Something to check..
>> > MKL (and anything built using the Intel compiler) has the "run slower on
>> > AMD" feature.  For any given operation, ACML won't necessarily be
>> > faster, but at least it's not intentionally crippled.  For most of what
>> > PETSc does, any such MKL/ACML difference is irrelevant.
>> > <configure.log><make.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150514/9b23273f/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150514/9b23273f/attachment.obj>
