[petsc-dev] hdf5 viewer question
Dominic Meiser dmeiser at txcorp.com
Tue Jun 23 12:39:37 CDT 2015
Hi Matt,
Thanks for your suggestion. I rebuilt with --with-64-bit-indices=1 but I
get the same result. Any other ideas?
Cheers,
Dominic
On 06/23/2015 09:23 AM, Matthew Knepley wrote:
> On Tue, Jun 23, 2015 at 9:38 AM, Dominic Meiser <dmeiser at txcorp.com
> <mailto:dmeiser at txcorp.com>> wrote:
>     Hi,
>     I'm running into an issue with the Hdf5 viewer. For parallel vectors
>     of length larger than 2^16 I get the error message below. The vector
>     is created from a 1D DMDA with 2 dofs. Serial vectors work fine as
>     do vectors of length <= 2^16. The error message is reproduced below.
>     The issue can be reproduced with the attached example with 'mpirun
>     -np 2 ./testcase -da_grid_x 65537'.
>     Do I need to configure the viewer in some way before using it?
> You may have to configure with --with-64-bit-indices
>    Thanks,
>      Matt
>     Thanks,
>     Dominic
>     HDF5-DIAG: Error detected in HDF5 (1.8.12) MPI-process 0:
>        #000: H5D.c line 170 in H5Dcreate2(): unable to create dataset
>          major: Dataset
>          minor: Unable to initialize object
>        #001: H5Dint.c line 439 in H5D__create_named(): unable to create
>     and link to dataset
>          major: Dataset
>        #002: H5L.c line 1638 in H5L_link_object(): unable to create new
>     link to object
>          major: Links
>        #003: H5L.c line 1882 in H5L_create_real(): can't insert link
>          major: Symbol table
>          minor: Unable to insert object
>        #004: H5Gtraverse.c line 861 in H5G_traverse(): internal path
>     traversal failed
>          major: Symbol table
>          minor: Object not found
>        #005: H5Gtraverse.c line 641 in H5G_traverse_real(): traversal
>     operator failed
>          major: Symbol table
>          minor: Callback failed
>        #006: H5L.c line 1685 in H5L_link_cb(): unable to create object
>          major: Object header
>        #007: H5O.c line 3015 in H5O_obj_create(): unable to open object
>     HDF5-DIAG: Error detected in HDF5 (1.8.12) MPI-process 1:
>          major: Dataset
>     and link to dataset
>          major: Dataset
>     link to object
>          major: Links
>          major: Symbol table
>     traversal failed
>          major: Symbol table
>     operator failed
>          major: Symbol table
>          minor: Can't open object
>        #008: H5Doh.c line 293 in H5O__dset_create(): unable to create
>     dataset
>          major: Dataset
>        #009: H5Dint.c line 1044 in H5D__create(): unable to construct
>     layout information
>          major: Dataset
>        #010: H5Dchunk.c line 539 in H5D__chunk_construct(): chunk size
>     must be <= maximum dimension size for fixed-sized dimensions
>          major: Dataset
>     dataset
>          major: Dataset
>     layout information
>          major: Dataset
>          major: Dataset
>     [0]PETSC ERROR: [1]PETSC ERROR: --------------------- Error Message
>     [0]PETSC ERROR: [1]PETSC ERROR: Error in external library
>     [0]PETSC ERROR: Error in HDF5 call H5Dcreate2() Status -1
>     [0]PETSC ERROR: [1]PETSC ERROR: Error in HDF5 call H5Dcreate2()
>     Status -1
>     [1]PETSC ERROR: See
>     http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
>     shooting.
>     See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
>     shooting.
>     [0]PETSC ERROR: Petsc Release Version 3.6.0, unknown
>     [0]PETSC ERROR: [1]PETSC ERROR: Petsc Release Version 3.6.0, unknown
>     [1]PETSC ERROR: ./testcase on a fftw_test named longspeak.txcorp.com
>     <http://longspeak.txcorp.com> by dmeiser Mon Jun 22 16:59:21 2015
>     [0]PETSC ERROR: Configure options --download-hdf5=1
>     --download-fftw=1 --with-mpi=1 PETSC_ARCH=fftw_test
>     [0]PETSC ERROR: [1]PETSC ERROR: Configure options --download-hdf5=1
>     [1]PETSC ERROR: #1 VecView_MPI_HDF5_DA() line 535 in
>     /home/scratch/petsc/src/dm/impls/da/gr2.c
>     [0]PETSC ERROR: #2 VecView_MPI_DA() line 713 in
>     [1]PETSC ERROR: #2 VecView_MPI_DA() line 713 in
>     [0]PETSC ERROR: #3 VecView() line 618 in
>     /home/scratch/petsc/src/vec/vec/interface/vector.c
>     [1]PETSC ERROR: #3 VecView() line 618 in
>     [0]PETSC ERROR: [1]PETSC ERROR: #4 dump() line 75 in testcase.c
>     [0]PETSC ERROR: #5 main() line 31 in testcase.c
>     [1]PETSC ERROR: #5 main() line 31 in testcase.c
>     [0]PETSC ERROR: [1]PETSC ERROR: PETSc Option Table entries:
>     [0]PETSC ERROR: -da_grid_x 65537
>     [1]PETSC ERROR: ----------------End of Error Message -------send
>     entire error message to petsc-maint at mcs.anl.gov----------
>     ----------------End of Error Message -------send entire error
>     [cli_0]: aborting job:
>     application called MPI_Abort(MPI_COMM_WORLD, 76) - process 0
>     [cli_1]: aborting job:
>     application called MPI_Abort(MPI_COMM_WORLD, 76) - process 1
>     =   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
>     =   PID 15847 RUNNING AT longspeak.txcorp.com
>     =   EXIT CODE: 76
>     =   CLEANING UP REMAINING PROCESSES
>     =   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
>     Dominic Meiser
>     Tech-X Corporation
>     5621 Arapahoe Avenue
>     Boulder, CO 80303
>     USA
>     Telephone: 303-996-2036 <tel:303-996-2036>
>     Fax: 303-448-7756 <tel:303-448-7756>
>     www.txcorp.com <http://www.txcorp.com>
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
Dominic Meiser
Tech-X Corporation
Boulder, CO 80303
USA
Fax: 303-448-7756
www.txcorp.com
