[petsc-dev] hdf5 viewer question
Tue Jun 23 12:24:17 CDT 2015
On Tue, Jun 23, 2015 at 12:39 PM, Dominic Meiser <dmeiser at txcorp.com> wrote:
> Hi Matt,
> Thanks for your suggestion. I rebuilt with --with-64-bit-indices=1 but I
> get the same result. Any other ideas?
There could be a bug with the calculation of chunksize. I will run your
example as soon as I can.
     Matt
> Cheers,
> Dominic
> On 06/23/2015 09:23 AM, Matthew Knepley wrote:
>> On Tue, Jun 23, 2015 at 9:38 AM, Dominic Meiser <dmeiser at txcorp.com
>> <mailto:dmeiser at txcorp.com>> wrote:
>>     Hi,
>>     I'm running into an issue with the Hdf5 viewer. For parallel vectors
>>     of length larger than 2^16 I get the error message below. The vector
>>     is created from a 1D DMDA with 2 dofs. Serial vectors work fine as
>>     do vectors of length <= 2^16. The error message is reproduced below.
>>     The issue can be reproduced with the attached example with 'mpirun
>>     -np 2 ./testcase -da_grid_x 65537'.
>>     Do I need to configure the viewer in some way before using it?
>> You may have to configure with --with-64-bit-indices
>>    Thanks,
>>      Matt
>>     Thanks,
>>     Dominic
>>     HDF5-DIAG: Error detected in HDF5 (1.8.12) MPI-process 0:
>>        #000: H5D.c line 170 in H5Dcreate2(): unable to create dataset
>>          major: Dataset
>>          minor: Unable to initialize object
>>        #001: H5Dint.c line 439 in H5D__create_named(): unable to create
>>     and link to dataset
>>          major: Dataset
>>        #002: H5L.c line 1638 in H5L_link_object(): unable to create new
>>     link to object
>>          major: Links
>>        #003: H5L.c line 1882 in H5L_create_real(): can't insert link
>>          major: Symbol table
>>          minor: Unable to insert object
>>        #004: H5Gtraverse.c line 861 in H5G_traverse(): internal path
>>     traversal failed
>>          major: Symbol table
>>          minor: Object not found
>>        #005: H5Gtraverse.c line 641 in H5G_traverse_real(): traversal
>>     operator failed
>>          major: Symbol table
>>          minor: Callback failed
>>        #006: H5L.c line 1685 in H5L_link_cb(): unable to create object
>>          major: Object header
>>        #007: H5O.c line 3015 in H5O_obj_create(): unable to open object
>>     HDF5-DIAG: Error detected in HDF5 (1.8.12) MPI-process 1:
>>          major: Dataset
>>     and link to dataset
>>          major: Dataset
>>     link to object
>>          major: Links
>>          major: Symbol table
>>     traversal failed
>>          major: Symbol table
>>     operator failed
>>          major: Symbol table
>>          minor: Can't open object
>>        #008: H5Doh.c line 293 in H5O__dset_create(): unable to create
>>     dataset
>>          major: Dataset
>>        #009: H5Dint.c line 1044 in H5D__create(): unable to construct
>>     layout information
>>          major: Dataset
>>        #010: H5Dchunk.c line 539 in H5D__chunk_construct(): chunk size
>>     must be <= maximum dimension size for fixed-sized dimensions
>>          major: Dataset
>>     dataset
>>          major: Dataset
>>     layout information
>>          major: Dataset
>>          major: Dataset
>>     [0]PETSC ERROR: [1]PETSC ERROR: --------------------- Error Message
>>     [0]PETSC ERROR: [1]PETSC ERROR: Error in external library
>>     [0]PETSC ERROR: Error in HDF5 call H5Dcreate2() Status -1
>>     [0]PETSC ERROR: [1]PETSC ERROR: Error in HDF5 call H5Dcreate2()
>>     Status -1
>>     [1]PETSC ERROR: See
>>     http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
>>     shooting.
>>     See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
>>     shooting.
>>     [0]PETSC ERROR: Petsc Release Version 3.6.0, unknown
>>     [0]PETSC ERROR: [1]PETSC ERROR: Petsc Release Version 3.6.0, unknown
>>     [1]PETSC ERROR: ./testcase on a fftw_test named longspeak.txcorp.com
>>     <http://longspeak.txcorp.com> by dmeiser Mon Jun 22 16:59:21 2015
>>     [0]PETSC ERROR: Configure options --download-hdf5=1
>>     --download-fftw=1 --with-mpi=1 PETSC_ARCH=fftw_test
>>     [0]PETSC ERROR: [1]PETSC ERROR: Configure options --download-hdf5=1
>>     [1]PETSC ERROR: #1 VecView_MPI_HDF5_DA() line 535 in
>>     /home/scratch/petsc/src/dm/impls/da/gr2.c
>>     [0]PETSC ERROR: #2 VecView_MPI_DA() line 713 in
>>     [1]PETSC ERROR: #2 VecView_MPI_DA() line 713 in
>>     [0]PETSC ERROR: #3 VecView() line 618 in
>>     /home/scratch/petsc/src/vec/vec/interface/vector.c
>>     [1]PETSC ERROR: #3 VecView() line 618 in
>>     [0]PETSC ERROR: [1]PETSC ERROR: #4 dump() line 75 in testcase.c
>>     [0]PETSC ERROR: #5 main() line 31 in testcase.c
>>     [1]PETSC ERROR: #5 main() line 31 in testcase.c
>>     [0]PETSC ERROR: [1]PETSC ERROR: PETSc Option Table entries:
>>     [0]PETSC ERROR: -da_grid_x 65537
>>     [1]PETSC ERROR: ----------------End of Error Message -------send
>>     entire error message to petsc-maint at mcs.anl.gov----------
>>     ----------------End of Error Message -------send entire error
>>     [cli_0]: aborting job:
>>     application called MPI_Abort(MPI_COMM_WORLD, 76) - process 0
>>     [cli_1]: aborting job:
>>     application called MPI_Abort(MPI_COMM_WORLD, 76) - process 1
>>     =   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
>>     =   PID 15847 RUNNING AT longspeak.txcorp.com
>>     =   EXIT CODE: 76
>>     =   CLEANING UP REMAINING PROCESSES
>>     =   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
>>     Dominic Meiser
>>     Tech-X Corporation
>>     5621 Arapahoe Avenue
>>     Boulder, CO 80303
>>     USA
>>     Telephone: 303-996-2036 <tel:303-996-2036>
>>     Fax: 303-448-7756 <tel:303-448-7756>
>>     www.txcorp.com <http://www.txcorp.com>
>> experiments is infinitely more interesting than any results to which
>> their experiments lead.
>> -- Norbert Wiener
> Dominic Meiser
> Tech-X Corporation
> Boulder, CO 80303
> USA
> Fax: 303-448-7756
> www.txcorp.com
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150623/1f8338cc/attachment.html>
