[petsc-dev] hdf5 viewer question
Tue Jun 23 10:23:12 CDT 2015
On Tue, Jun 23, 2015 at 9:38 AM, Dominic Meiser <dmeiser at txcorp.com> wrote:
> Hi,
> I'm running into an issue with the Hdf5 viewer. For parallel vectors of
> length larger than 2^16 I get the error message below. The vector is
> created from a 1D DMDA with 2 dofs. Serial vectors work fine as do vectors
> of length <= 2^16. The error message is reproduced below. The issue can be
> reproduced with the attached example with 'mpirun -np 2 ./testcase
> -da_grid_x 65537'.
> Do I need to configure the viewer in some way before using it?
You may have to configure with --with-64-bit-indices
    Matt
> Thanks,
> Dominic
> HDF5-DIAG: Error detected in HDF5 (1.8.12) MPI-process 0:
>   #000: H5D.c line 170 in H5Dcreate2(): unable to create dataset
>     major: Dataset
>     minor: Unable to initialize object
>   #001: H5Dint.c line 439 in H5D__create_named(): unable to create and
> link to dataset
>     major: Dataset
>   #002: H5L.c line 1638 in H5L_link_object(): unable to create new link to
> object
>     major: Links
>   #003: H5L.c line 1882 in H5L_create_real(): can't insert link
>     major: Symbol table
>     minor: Unable to insert object
>   #004: H5Gtraverse.c line 861 in H5G_traverse(): internal path traversal
> failed
>     major: Symbol table
>     minor: Object not found
>   #005: H5Gtraverse.c line 641 in H5G_traverse_real(): traversal operator
> failed
>     major: Symbol table
>     minor: Callback failed
>   #006: H5L.c line 1685 in H5L_link_cb(): unable to create object
>     major: Object header
>   #007: H5O.c line 3015 in H5O_obj_create(): unable to open object
> HDF5-DIAG: Error detected in HDF5 (1.8.12) MPI-process 1:
>     major: Dataset
> link to dataset
>     major: Dataset
> object
>     major: Links
>     major: Symbol table
> failed
>     major: Symbol table
> failed
>     major: Symbol table
>     minor: Can't open object
>   #008: H5Doh.c line 293 in H5O__dset_create(): unable to create dataset
>     major: Dataset
>   #009: H5Dint.c line 1044 in H5D__create(): unable to construct layout
> information
>     major: Dataset
>   #010: H5Dchunk.c line 539 in H5D__chunk_construct(): chunk size must be
> <= maximum dimension size for fixed-sized dimensions
>     major: Dataset
>     major: Dataset
> information
>     major: Dataset
>     major: Dataset
> [0]PETSC ERROR: [1]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: [1]PETSC ERROR: Error in external library
> [0]PETSC ERROR: Error in HDF5 call H5Dcreate2() Status -1
> [0]PETSC ERROR: [1]PETSC ERROR: Error in HDF5 call H5Dcreate2() Status -1
> [1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
> shooting.
> [0]PETSC ERROR: Petsc Release Version 3.6.0, unknown
> [0]PETSC ERROR: [1]PETSC ERROR: Petsc Release Version 3.6.0, unknown
> [1]PETSC ERROR: ./testcase on a fftw_test named longspeak.txcorp.com by
> dmeiser Mon Jun 22 16:59:21 2015
> ./testcase on a fftw_test named longspeak.txcorp.com by dmeiser Mon Jun
> 22 16:59:21 2015
> [0]PETSC ERROR: Configure options --download-hdf5=1 --download-fftw=1
> --with-mpi=1 PETSC_ARCH=fftw_test
> [0]PETSC ERROR: [1]PETSC ERROR: Configure options --download-hdf5=1
> --download-fftw=1 --with-mpi=1 PETSC_ARCH=fftw_test
> [1]PETSC ERROR: #1 VecView_MPI_HDF5_DA() line 535 in
> /home/scratch/petsc/src/dm/impls/da/gr2.c
> [0]PETSC ERROR: #2 VecView_MPI_DA() line 713 in
> [1]PETSC ERROR: #2 VecView_MPI_DA() line 713 in
> [0]PETSC ERROR: #3 VecView() line 618 in
> /home/scratch/petsc/src/vec/vec/interface/vector.c
> [1]PETSC ERROR: #3 VecView() line 618 in
> [0]PETSC ERROR: [1]PETSC ERROR: #4 dump() line 75 in testcase.c
> [0]PETSC ERROR: #5 main() line 31 in testcase.c
> [1]PETSC ERROR: #5 main() line 31 in testcase.c
> [0]PETSC ERROR: [1]PETSC ERROR: PETSc Option Table entries:
> [0]PETSC ERROR: -da_grid_x 65537
> [1]PETSC ERROR: ----------------End of Error Message -------send entire
> error message to petsc-maint at mcs.anl.gov----------
> ----------------End of Error Message -------send entire error message to
> [cli_0]: aborting job:
> application called MPI_Abort(MPI_COMM_WORLD, 76) - process 0
> [cli_1]: aborting job:
> application called MPI_Abort(MPI_COMM_WORLD, 76) - process 1
> =   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
> =   PID 15847 RUNNING AT longspeak.txcorp.com
> =   EXIT CODE: 76
> =   CLEANING UP REMAINING PROCESSES
> =   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
> Dominic Meiser
> Tech-X Corporation
> 5621 Arapahoe Avenue
> Boulder, CO 80303
> USA
> Telephone: 303-996-2036
> Fax: 303-448-7756
> www.txcorp.com
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150623/627c3a0a/attachment.html>
