[petsc-dev] Titan error
Fri Jun 5 10:58:31 CDT 2015
On Fri, 5 Jun 2015, Mark Adams wrote:
> THis script worked a few months ago.  I will try to build with a prefix,
> just to see if that is the only problem.
Configure Options: --configModules=PETSc.Configure --optionsModule=config.compilerOptions --COPTFLAGS="-mp -fast" --CXXOPTFLAGS="-mp -fast" --FOPTFLAGS="-mp -fast" --with-ssl=0 --prefix=/autofs/na3_home1/adams/petsc_master_opt64idx_pgi --download-metis --with-hwloc=0 --download-parmetis --with-cc=cc --with-cxx=CC --with-fc=ftn --with-shared-libraries=0 --known-mpi-shared-libraries=1 --with-x=0 --with-64-bit-indices --with-debugging=0 PETSC_ARCH=arch-titan-opt64idx-pgi PETSC_DIR=/lustre/atlas/scratch/adams/env003/petsc
You did use prefix - so perhaps you meant 'build without prefix'
Satish
