[petsc-dev] Titan error
Mark Adams mfadams at lbl.gov
Fri Jun 5 15:24:18 CDT 2015
This works without prefix.  I tried prefixing to the compute directories,
where I run config, and got the same error.  Config thinks that it does not
have permission.  I did see a password prompt at one point.
Treb, I just configured in a normal way and copied the directory into my
home direcory.  So try:
make PETSC_DIR=/autofs/nccs-svm1_home1/adams/petsc_treb
PETSC_ARCH=arch-titan-opt64idx-pgi
On Fri, Jun 5, 2015 at 9:56 AM, Mark Adams <mfadams at lbl.gov> wrote:
> On Thu, Jun 4, 2015 at 10:53 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>   Hmm,
>> You do not have write permissions to the --prefix directory
>> /autofs/na3_home1/adams/petsc_master_opt64idx_pgi
>>                           You will be prompted for the sudo password for
>> any external package installs
>> Do you have write permission for this directory?
>> To test if you have write permission it does the following code:
>> def setInstallDir(self):
>>     ''' setup installDir to either prefix or if that is not set to
>> PETSC_DIR/PETSC_ARCH'''
>>     self.installSudo        = ''
>>     self.installSudoMessage = ''
>>     if self.framework.argDB['prefix']:
>>       self.dir = self.framework.argDB['prefix']
>>       try:
>>         os.makedirs(os.path.join(self.dir,'PETScTestDirectory'))
>>         os.rmdir(os.path.join(self.dir,'PETScTestDirectory'))
>>       except:
>>         self.installSudoMessage = 'You do not have write permissions to
>> the --prefix directory '+self.dir+'\nYou will be prompted for the sudo
>> password for any external package installs'
>> Can you make a directory in /autofs/na3_home1/adams/ ?
> This is my home directory:
> env003/petsc> ll -a /autofs/na3_home1/adams/
> total 20544
> drwxr-xr-x   39 adams users    12288 May 16 07:21 .
> drwxr-xr-x 5027 root  root    163840 May 22 16:05 ..
> drwxr-xr-x    6 adams adams     4096 Jan  9 07:26 .allinea
> THis script worked a few months ago.  I will try to build with a prefix,
> just to see if that is the only problem.
>>   Barry
>> > On Jun 4, 2015, at 9:43 PM, Mark Adams <mfadams at lbl.gov> wrote:
>> > Yet again, this one does have a slightly amusing and slightly baffling
>> error message though.
>> > Mark
>> > <configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150605/b4e527c3/attachment.html>
