[petsc-dev] memory leak
Mark Adams mfadams at lbl.gov
Mon Jun 1 08:08:34 CDT 2015
> Send the command that you used to create the branch.
Matt, I just cloned PETSc/master.  I did not create any branches.
>     Matt
>> Anyway, I've blown it away and am starting with a fresh clone.
>> Thanks again,
>>>    Matt
>>>> Thanks,
>>>> Mark
>>>>>    Matt
>>>>>> from another branch, at least I did not knowingly.  I am tempted to
>>>>>> just start with a fresh clone and redo this whole thing.
>>>>>> What is going on here?  Did I sleep walk last night and pull from
>>>>>> next?
>>>>>> Can I just push this to master (I tested it and it is a trivial
>>>>>> change) or should I reclone. etc.?
>>>>>> Mark
>>>>>> 19:10 edison03 master ~/petsc$ git status
>>>>>> # On branch master
>>>>>> # Your branch is ahead of 'origin/master' by 7 commits.
>>>>>> # Changes not staged for commit:
>>>>>> #   (use "git add <file>..." to update what will be committed)
>>>>>> #   (use "git checkout -- <file>..." to discard changes in working
>>>>>> directory)
>>>>>> #       modified:
>>>>>> src/ksp/pc/impls/fieldsplit/ftn-custom/zfieldsplitf.c
>>>>>> no changes added to commit (use "git add" and/or "git commit -a")
>>>>>> 19:10 edison03 master ~/petsc$ git commit
>>>>>> src/ksp/pc/impls/fieldsplit/ftn-custom/zfieldsplitf.c -m"fixed memory leak"
>>>>>> [master d4dcd7b] fixed memory leak
>>>>>>  1 file changed, 1 insertion(+)
>>>>>> 19:10 edison03 master ~/petsc$ git pull origin master
>>>>>> From https://bitbucket.org/petsc/petsc
>>>>>>  * branch            master     -> FETCH_HEAD
>>>>>> Already up-to-date.
>>>>>> 19:11 edison03 master ~/petsc$ git status
>>>>>> # On branch master
>>>>>> # Your branch is ahead of 'origin/master' by 8 commits.
>>>>>> nothing to commit (working directory clean)
>>>>>> On Sun, May 31, 2015 at 10:02 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>> This is coming from this line (last):
>>>>>>> #undef __FUNCT__
>>>>>>> #define __FUNCT__ "PCFieldSplitGetSubKSP_FieldSplit_Schur"
>>>>>>> static PetscErrorCode  PCFieldSplitGetSubKSP_FieldSplit_Schur(PC
>>>>>>> pc,PetscInt *n,KSP **subksp)
>>>>>>>   PC_FieldSplit  *jac = (PC_FieldSplit*)pc->data;
>>>>>>>   PetscErrorCode ierr;
>>>>>>>   PetscFunctionBegin;
>>>>>>>   ierr = PetscMalloc1(jac->nsplits,subksp);CHKERRQ(ierr);
>>>>>>> I call it with:
>>>>>>>   KSP::subksp(2)
>>>>>>>   call
>>>>>>> PCFieldSplitGetSubKSP(solver%pc,PETSC_NULL_INTEGER,subksp,ierr)
>>>>>>> The Fortran wrapper is:
>>>>>>> PETSC_EXTERN void PETSC_STDCALL pcfieldsplitgetsubksp_(PC
>>>>>>> *pc,PetscInt *n_local,KSP *ksp,PetscErrorCode *ierr)
>>>>>>>   KSP      *tksp;
>>>>>>>   PetscInt i,nloc;
>>>>>>>   CHKFORTRANNULLINTEGER(n_local);
>>>>>>>   *ierr = PCFieldSplitGetSubKSP(*pc,&nloc,&tksp); if (*ierr) return;
>>>>>>>   if (n_local) *n_local = nloc;
>>>>>>>   CHKFORTRANNULLOBJECT(ksp);
>>>>>>>   if (ksp) {
>>>>>>>     for (i=0; i<nloc; i++) ksp[i] = tksp[i];
>>>>>>> Should I just add a PetscFree(&tksp) here?
>>>>>>> On Sun, May 31, 2015 at 7:24 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>>> On Sat, May 30, 2015 at 10:51 PM, Barry Smith <bsmith at mcs.anl.gov>
>>>>>>>> wrote:
>>>>>>>>>  Need more details. How can we reproduce this?
>>>>>>>> I was hoping this would be obvious. a missed free.
>>>>>>>> What tests use Schur solvers?  I could see if they have the same
>>>>>>>> problem.
>>>>>>>>>   Barry
>>>>>>>>> > On May 30, 2015, at 7:10 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>>>> > This look like there might be a memory leak in PETSc.  Let me
>>>>>>>>> know if this is not obvious and get more detail.
>>>>>>>>> > Mark
>>>>>>>>> > [0]Total space allocated 16 bytes
>>>>>>>>> > [ 0]16 bytes PCFieldSplitGetSubKSP_FieldSplit_Schur() line 1263
>>>>>>>>> in /global/u2/m/madams/petsc/src/ksp/pc/impls/fieldsplit/fieldsplit.c
>>>>>>>>> >       [0]  PCFieldSplitGetSubKSP_FieldSplit_Schur() line 1263 in
>>>>>>>>> >       [0]  PCFieldSplitGetSubKSP() line 1665 in
>>>>>>>>> >       [0]  KSPSetUp() line 247 in
>>>>>>>>> /global/u2/m/madams/petsc/src/ksp/ksp/interface/itfunc.c
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150601/d2b952cd/attachment.html>
