[petsc-dev] memory leak
Mon Jun 1 08:23:35 CDT 2015
On Mon, Jun 1, 2015 at 8:08 AM, Mark Adams <mfadams at lbl.gov> wrote:
>> Send the command that you used to create the branch.
> Matt, I just cloned PETSc/master.  I did not create any branches.
1) Cloning just creates a repository structure. You have to keep pulling to
get things up to date.
2) You are always working on a branch, no matter what you cloned. You can
see the branch that
     you are on using 'git branch' (it is the one with the star).
3) A branch is a list of commits. The 'branch' command makes a new line
from this list starting at the
    current commit (so that you have a tree). Thus, when you type "branch"
there is an implicit a) branch
    you are on, and b) current commit. We are just trying to get those
right.
     Matt
>   Thanks,
>>     Matt
>>> Anyway, I've blown it away and am starting with a fresh clone.
>>> Thanks again,
>>>>    Matt
>>>>> Thanks,
>>>>> Mark
>>>>>>    Matt
>>>>>>> from another branch, at least I did not knowingly.  I am tempted to
>>>>>>> just start with a fresh clone and redo this whole thing.
>>>>>>> What is going on here?  Did I sleep walk last night and pull from
>>>>>>> next?
>>>>>>> Can I just push this to master (I tested it and it is a trivial
>>>>>>> change) or should I reclone. etc.?
>>>>>>> Mark
>>>>>>> 19:10 edison03 master ~/petsc$ git status
>>>>>>> # On branch master
>>>>>>> # Your branch is ahead of 'origin/master' by 7 commits.
>>>>>>> # Changes not staged for commit:
>>>>>>> #   (use "git add <file>..." to update what will be committed)
>>>>>>> #   (use "git checkout -- <file>..." to discard changes in working
>>>>>>> directory)
>>>>>>> #       modified:
>>>>>>> src/ksp/pc/impls/fieldsplit/ftn-custom/zfieldsplitf.c
>>>>>>> no changes added to commit (use "git add" and/or "git commit -a")
>>>>>>> 19:10 edison03 master ~/petsc$ git commit
>>>>>>> src/ksp/pc/impls/fieldsplit/ftn-custom/zfieldsplitf.c -m"fixed memory leak"
>>>>>>> [master d4dcd7b] fixed memory leak
>>>>>>>  1 file changed, 1 insertion(+)
>>>>>>> 19:10 edison03 master ~/petsc$ git pull origin master
>>>>>>> From https://bitbucket.org/petsc/petsc
>>>>>>>  * branch            master     -> FETCH_HEAD
>>>>>>> Already up-to-date.
>>>>>>> 19:11 edison03 master ~/petsc$ git status
>>>>>>> # On branch master
>>>>>>> # Your branch is ahead of 'origin/master' by 8 commits.
>>>>>>> nothing to commit (working directory clean)
>>>>>>> On Sun, May 31, 2015 at 10:02 PM, Mark Adams <mfadams at lbl.gov>
>>>>>>> wrote:
>>>>>>>> This is coming from this line (last):
>>>>>>>> #undef __FUNCT__
>>>>>>>> #define __FUNCT__ "PCFieldSplitGetSubKSP_FieldSplit_Schur"
>>>>>>>> static PetscErrorCode  PCFieldSplitGetSubKSP_FieldSplit_Schur(PC
>>>>>>>> pc,PetscInt *n,KSP **subksp)
>>>>>>>>   PC_FieldSplit  *jac = (PC_FieldSplit*)pc->data;
>>>>>>>>   PetscErrorCode ierr;
>>>>>>>>   PetscFunctionBegin;
>>>>>>>>   ierr = PetscMalloc1(jac->nsplits,subksp);CHKERRQ(ierr);
>>>>>>>> I call it with:
>>>>>>>>   KSP::subksp(2)
>>>>>>>>   call
>>>>>>>> PCFieldSplitGetSubKSP(solver%pc,PETSC_NULL_INTEGER,subksp,ierr)
>>>>>>>> The Fortran wrapper is:
>>>>>>>> PETSC_EXTERN void PETSC_STDCALL pcfieldsplitgetsubksp_(PC
>>>>>>>> *pc,PetscInt *n_local,KSP *ksp,PetscErrorCode *ierr)
>>>>>>>>   KSP      *tksp;
>>>>>>>>   PetscInt i,nloc;
>>>>>>>>   CHKFORTRANNULLINTEGER(n_local);
>>>>>>>>   *ierr = PCFieldSplitGetSubKSP(*pc,&nloc,&tksp); if (*ierr) return;
>>>>>>>>   if (n_local) *n_local = nloc;
>>>>>>>>   CHKFORTRANNULLOBJECT(ksp);
>>>>>>>>   if (ksp) {
>>>>>>>>     for (i=0; i<nloc; i++) ksp[i] = tksp[i];
>>>>>>>> Should I just add a PetscFree(&tksp) here?
>>>>>>>> On Sun, May 31, 2015 at 7:24 PM, Mark Adams <mfadams at lbl.gov>
>>>>>>>> wrote:
>>>>>>>>> On Sat, May 30, 2015 at 10:51 PM, Barry Smith <bsmith at mcs.anl.gov>
>>>>>>>>> wrote:
>>>>>>>>>>  Need more details. How can we reproduce this?
>>>>>>>>> I was hoping this would be obvious. a missed free.
>>>>>>>>> What tests use Schur solvers?  I could see if they have the same
>>>>>>>>> problem.
>>>>>>>>>>   Barry
>>>>>>>>>> > On May 30, 2015, at 7:10 PM, Mark Adams <mfadams at lbl.gov>
>>>>>>>>>> wrote:
>>>>>>>>>> > This look like there might be a memory leak in PETSc.  Let me
>>>>>>>>>> know if this is not obvious and get more detail.
>>>>>>>>>> > Mark
>>>>>>>>>> > [0]Total space allocated 16 bytes
>>>>>>>>>> > [ 0]16 bytes PCFieldSplitGetSubKSP_FieldSplit_Schur() line 1263
>>>>>>>>>> in /global/u2/m/madams/petsc/src/ksp/pc/impls/fieldsplit/fieldsplit.c
>>>>>>>>>> >       [0]  PCFieldSplitGetSubKSP_FieldSplit_Schur() line 1263
>>>>>>>>>> >       [0]  PCFieldSplitGetSubKSP() line 1665 in
>>>>>>>>>> >       [0]  KSPSetUp() line 247 in
>>>>>>>>>> /global/u2/m/madams/petsc/src/ksp/ksp/interface/itfunc.c
>>>>>> What most experimenters take for granted before they begin their
>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150601/5298b475/attachment.html>
