[petsc-dev] Fortran seems broken
Mark Adams mfadams at lbl.gov
Fri Jan 23 13:33:13 CST 2015
oh and I do have the logs.
On Fri, Jan 23, 2015 at 12:56 PM, Matthew Knepley <knepley at gmail.com> wrote:
> It wants the petscmat.mod module. Can you send the compile line?
>    Matt
> On Fri, Jan 23, 2015 at 11:54 AM, Mark Adams <mfadams at lbl.gov> wrote:
>> This code has started failing.  I've change finclude -->petsc-finclude
>> #include <petsc-finclude/petscdef.h>
>>   use petscmat
>> I get:
>> fem_ops.F90(19): error #7002: Error in opening the compiled module file.
>> Check INCLUDE paths.   [PETSCMAT]
>>   use petscmat
>> I've clobbered the confugure.log but can regenerate it if need be.
>> Thanks,
>> Mark
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150123/4903fb3a/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150123/4903fb3a/attachment.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150123/4903fb3a/attachment-0001.obj>
