[petsc-dev] Fortran seems broken
Fri Jan 23 13:42:08 CST 2015
What do you have for:
ls -l /global/u2/m/madams/petsc_private/arch-xc30-opt64-intel/include/
Satish
On Fri, 23 Jan 2015, Mark Adams wrote:
> oh and I do have the logs.
> On Fri, Jan 23, 2015 at 12:56 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > It wants the petscmat.mod module. Can you send the compile line?
> >    Matt
> > On Fri, Jan 23, 2015 at 11:54 AM, Mark Adams <mfadams at lbl.gov> wrote:
> >> This code has started failing.  I've change finclude -->petsc-finclude
> >> #include <petsc-finclude/petscdef.h>
> >>   use petscmat
> >> I get:
> >> fem_ops.F90(19): error #7002: Error in opening the compiled module file.
> >> Check INCLUDE paths.   [PETSCMAT]
> >>   use petscmat
> >> I've clobbered the confugure.log but can regenerate it if need be.
> >> Thanks,
> >> Mark
> > What most experimenters take for granted before they begin their
> > experiments is infinitely more interesting than any results to which their
> > experiments lead.
> > -- Norbert Wiener
