[petsc-dev] Fortran seems broken
Mark Adams mfadams at lbl.gov
Fri Jan 23 13:27:32 CST 2015
It looks like it is missing include info as well as the modules.
09:46 2 edison01 core_dev ~/epsi/XGC1_3$ make -f Makefile.edison
ftn -g -openmp -no-ipo -DADIOS -DUSE_BICUB_MOD -DUSE_ONE_D_I_CUB_MOD
-I/global/homes/m/madams/petsc_private/arch-xe6-opt64-pgi/include
-I/global/homes/m/madams/petsc_private/include -DADIOS_WRITE_NEW
-DADIOS_NEW_INIT -DADIOS_READ_V2 -DADIOS_READ_NEW  -DITER_GRID
-I/usr/common/usg/adios/1.6.0/intel/include -DCOL_MIRA_ION -DCOL_MIRA_ELEC
   -DPSPLINE -I/usr/common/usg/pspline/nersc1.0/intel/mod -DCAM_TIMERS
-I../camtimers  -I/opt/cray/mpt/6.0.1/gni/mpich2-pgi/121/include
-I/opt/cray/papi/5.1.2/perf_events/no-cuda/include
-I/opt/cray/udreg/2.3.2-1.0402.7546.1.5.gem/include
-I/opt/cray/ugni/5.0-1.0402.7551.1.10.gem/include
-I/opt/cray/pmi/4.0.1-1.0000.9753.86.3.gem/include
-I/opt/cray/dmapp/4.0.1-1.0402.7784.4.1.gem/include
-I/opt/cray/gni-headers/2.1-1.0402.7541.1.5.gem/include
-I/opt/cray/xpmem/0.1-2.0402.45248.1.5.gem/include
-I/opt/cray/rca/1.0.0-2.0402.47290.7.1.gem/include
-I/opt/cray-hss-devel/7.1.0/include
-I/opt/cray/krca/1.0.0-2.0402.46083.4.47.gem/include
-I/opt/cray/mpt/6.0.1/gni/sma/include
-I/opt/cray/libsci/12.1.01/pgi/121/mc12/include -I/usr/include/alps
-I/opt/cray/hdf5/1.8.11/pgi/121/include
-I/opt/pgi/13.6.0/linux86-64/13.6/include
-I/opt/cray/xe-sysroot/4.2.34/usr/include -c fem_ops.F90
fem_ops.F90(19): error #7002: Error in opening the compiled module file.
Check INCLUDE paths.   [PETSCMAT]
  use petscmat
fem_ops.F90(112): error #7002: Error in opening the compiled module file.
  use petscmat
fem_ops.F90(158): error #6404: This name does not have a type, and must
have an explicit type.   [ADD_VALUES]
                 call
MatSetValues(Amat,ione,idi,ione,idj,arr(itmp,jtmp),ADD_VALUES,ierr)
fem_ops.F90(159): error #6404: This name does not have a type, and must
have an explicit type.   [PETSC_COMM_WORLD]
                 if (ierr .ne. 0) call MPI_Abort(PETSC_COMM_WORLD,ierr,ierr)
fem_ops.F90(178): error #6404: This name does not have a type, and must
have an explicit type.   [MAT_FINAL_ASSEMBLY]
  call MatAssemblyBegin(Amat,MAT_FINAL_ASSEMBLY,ierr)
fem_ops.F90(307): error #7002: Error in opening the compiled module file.
Check INCLUDE paths.   [PETSCKSP]
  use petscksp
fem_ops.F90(323): error #6404: This name does not have a type, and must
have an explicit type.   [PETSC_NULL_CHARACTER]
  call PetscInitialize(PETSC_NULL_CHARACTER,ierr)
fem_ops.F90(324): error #6404: This name does not have a type, and must
  call MPI_Comm_size(PETSC_COMM_WORLD,npe,ierr)
fem_ops.F90(329): error #6404: This name does not have a type, and must
have an explicit type.   [PETSC_DECIDE]
  call MatSetSizes( Amat,PETSC_DECIDE, PETSC_DECIDE, nnodes, nnodes, ierr )
fem_ops.F90(335): error #6404: This name does not have a type, and must
have an explicit type.   [PETSC_NULL_INTEGER]
  call MatSeqAIJSetPreallocation(Amat,9,PETSC_NULL_INTEGER,ierr)
fem_ops.F90(344): error #6404: This name does not have a type, and must
have an explicit type.   [SAME_NONZERO_PATTERN]
  call KSPSetOperators(solver,Amat,Amat,SAME_NONZERO_PATTERN,ierr)
On Fri, Jan 23, 2015 at 12:56 PM, Matthew Knepley <knepley at gmail.com> wrote:
> It wants the petscmat.mod module. Can you send the compile line?
>    Matt
> On Fri, Jan 23, 2015 at 11:54 AM, Mark Adams <mfadams at lbl.gov> wrote:
>> This code has started failing.  I've change finclude -->petsc-finclude
>> #include <petsc-finclude/petscdef.h>
>>   use petscmat
>> I get:
>>   use petscmat
>> I've clobbered the confugure.log but can regenerate it if need be.
>> Thanks,
>> Mark
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150123/f5a66262/attachment.html>
