[petsc-dev] Fortran seems broken
Fri Jan 23 11:56:13 CST 2015
It wants the petscmat.mod module. Can you send the compile line?
   Matt
On Fri, Jan 23, 2015 at 11:54 AM, Mark Adams <mfadams at lbl.gov> wrote:
> This code has started failing.  I've change finclude -->petsc-finclude
> #include <petsc-finclude/petscdef.h>
>   use petscmat
> I get:
> fem_ops.F90(19): error #7002: Error in opening the compiled module file.
> Check INCLUDE paths.   [PETSCMAT]
>   use petscmat
> I've clobbered the confugure.log but can regenerate it if need be.
> Thanks,
> Mark
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150123/5fe2cd6c/attachment.html>
