[petsc-dev] configure tetgen error
Tue Jan 13 21:48:26 CST 2015
On Tue, 13 Jan 2015, Satish Balay wrote:
> Will push to barry/namespace-install [and merge to master/next]
However 'next' gives the following error.
home/balay/petsc/src/snes/linesearch/impls/nleqerr/linesearchnleqerr.c: In function ‘SNESLineSearchApply_NLEQERR’:
/home/balay/petsc/src/snes/linesearch/impls/nleqerr/linesearchnleqerr.c:111:10: error: ‘true’ undeclared (first use in this function)
   while (true) {
/home/balay/petsc/src/snes/linesearch/impls/nleqerr/linesearchnleqerr.c:111:10: note: each undeclared identifier is reported only once for each function it appears in
gmakefile:161: recipe for target 'arch-next-ctetgen/obj/src/snes/linesearch/impls/nleqerr/linesearchnleqerr.o' failed
So the following fix?
$ git diff |cat
diff --git a/src/snes/linesearch/impls/nleqerr/linesearchnleqerr.c b/src/snes/linesearch/impls/nleqerr/linesearchnleqerr.c
index c275d9a..1b80b85 100644
--- a/src/snes/linesearch/impls/nleqerr/linesearchnleqerr.c
+++ b/src/snes/linesearch/impls/nleqerr/linesearchnleqerr.c
@@ -108,7 +108,7 @@ static PetscErrorCode  SNESLineSearchApply_NLEQERR(SNESLineSearch linesearch)
      At the end of this while loop, G should have the accepted new X in it. */
   count = 0;
-  while (true) {
+  while (PETSC_TRUE) {
     if (monitor) {
       ierr = PetscViewerASCIIAddTab(monitor,((PetscObject)linesearch)->tablevel);CHKERRQ(ierr);
       ierr = PetscViewerASCIIPrintf(monitor,"    Line search: entering iteration with lambda: %14.12e\n", lambda);CHKERRQ(ierr);
But which branch does this fix go to? I don't see this branch in petsc
repo. I see Matt merged this to master - so will leave it to
Matt/Patrick to resolve..
Satish
$ git branch -r --contains d4c6564c
  origin/next
commit 2e51616568b6d7c20fc05db6793a1a176d001d82
Merge: f0fa725 d4c6564
Author: Matthew G. Knepley <knepley at gmail.com>
Date:   Tue Jan 13 12:57:14 2015 -0600
    Merge branch 'pefarrell/linesearch-nleqerr' into next
    * pefarrell/linesearch-nleqerr:
      Implement the NLEQ-ERR linesearch of Deuflhard (2011).
commit d4c6564c171d7f6bffed680177fba1cf86876815
Author: Patrick Farrell <patrick.farrell at imperial.ac.uk>
Date:   Sun Jan 11 21:26:19 2015 +0000
