[petsc-dev] configure tetgen error
Tue Jan 13 21:39:44 CST 2015
  Jed and his damn, you can't have those pull branches, they need to be commits! Making extra work for Satish :-)
> On Jan 13, 2015, at 9:35 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> Ah - I forgot to pull ctetgen repo [to check new changes].
> However ctetgen.py (in next) is not updated to use this new stuff. It will need the following fix.
> Will push to barry/namespace-install [and merge to master/next]
> Satish
> $ git diff |cat
> diff --git a/config/BuildSystem/config/packages/ctetgen.py b/config/BuildSystem/config/packages/ctetgen.py
> index 3f1c759..f3fd0ff 100644
> --- a/config/BuildSystem/config/packages/ctetgen.py
> +++ b/config/BuildSystem/config/packages/ctetgen.py
> @@ -4,9 +4,9 @@ import os
> class Configure(config.package.GNUPackage):
>   def __init__(self, framework):
>     config.package.GNUPackage.__init__(self, framework)
> -    self.gitcommit         = '622d9a06ef18638e7521f2a870d62f5c28f182e1'
> +    self.gitcommit         = '0616e704bcc37b1df8705f614c63bf8e9e51ee80'
>     self.giturls           = ['https://bitbucket.org/petsc/ctetgen.git']
> -    self.download          = ['http://ftp.mcs.anl.gov/pub/petsc/externalpackages/ctetgen-0.2.tar.gz']
> +    self.download          = ['http://ftp.mcs.anl.gov/pub/petsc/externalpackages/ctetgen-0.3.tar.gz']
>     self.functions         = []
>     self.includes          = []
>     return
> On Tue, 13 Jan 2015, Barry Smith wrote:
>>  I made those changes. Did I forget to push them and then deleted the directory?
>>  Barry
>>> On Jan 13, 2015, at 9:12 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>>> looks like ctetgen requires the following change [to be in sync with
>>> 'conf' -> 'petsc-conf' change on the petsc makefile side]
>>> Satish
>>> balay at asterix /home/balay/git-repo/ctetgen (master *=)
>>> $ git diff |cat
>>> diff --git a/makefile b/makefile
>>> index 7e97840..f4d6a20 100644
>>> --- a/makefile
>>> +++ b/makefile
>>> @@ -10,13 +10,13 @@ DIRS     =
>>> MANSEC   =
>>> LOCDIR   =
>>> -include ${PETSC_DIR}/conf/variables
>>> +include ${PETSC_DIR}/lib/petsc-conf/variables
>>> LIBBASE    = libctetgen
>>> LIBNAME    = ${LIBBASE}.${AR_LIB_SUFFIX}
>>> CLEANFILES = ${LIBNAME}
>>> -include ${PETSC_DIR}/conf/rules
>>> +include ${PETSC_DIR}/lib/petsc-conf/rules
>>> install-ctetgen:
>>>       ${MKDIR} ${DESTDIR}/include
>>> On Tue, 13 Jan 2015, Adrian Croucher wrote:
>>>> hi
>>>> Just pulled next branch and tried to reconfigure, but it chokes when trying to
>>>> compile tetgen (I use the --download-ctetgen option):
>>>> Error running make on Ctetgen: Could not execute "cd
>>>> /home/acro018/software/PETSc/code/linux-gnu-c-opt/externalpackages/ctetgen &&
>>>> /usr/bin/make PET
>>>> SC_DIR=/home/acro018/software/PETSc/code clean lib":
>>>> makefile:13: /home/acro018/software/PETSc/code/conf/variables: No such file or
>>>> directory
>>>> makefile:19: /home/acro018/software/PETSc/code/conf/rules: No such file or
>>>> directory
>>>> make: *** No rule to make target
>>>> `/home/acro018/software/PETSc/code/conf/rules'.  Stop.
>>>> Is this a casualty of recent changes to paths- or have I messed something up?
>>>> Cheers, Adrian
