[petsc-dev] unwind next branch
Jed Brown jed at jedbrown.org
Tue Sep 9 17:58:55 CDT 2014
Satish Balay <balay at mcs.anl.gov> writes:
> Jed,
> After 3.5 release we have not unwound next branch.
> With 3.5.2 out - is it a good time to unwind?
> This might need some coordination as there are some old branches that
> are not yet merged to master/next.. (so they need rebase?)
I'd rather re-merge than rebase unless there was something wrong with the original version.
> balay at asterix /home/balay/petsc (master)
> $ comm -12 <(git branch -r --merged next | sort) <(git branch -r --no-merged master | sort)
>   origin/balay/fix-glibc-2.20_DEFAULT_SOURCE
>   origin/balay/update-etags
>   origin/balay/update-hdf5
>   origin/jed/sr-driver4
>   origin/jed/vecghostgetvalues
>   origin/karpeev/fix-ksp-pcgasm
>   origin/knepley/feature-optcontrol-mg
>   origin/knepley/feature-plex-nasm
>   origin/knepley/feature-quadrature-fortran
>   origin/knepley/fix-quadrature-order
>   origin/madams/sr-driver4
>   origin/mlange05/fix-gmsh-coordinates
>   origin/next
>   origin/paulmullowney/aijcusp-ellpack-fix
>   origin/prbrune/sf-examplefix
>   origin/prbrune/snes-ex19vtkoutput
>   origin/sarich/fix-tao-linesearch-reset
>   origin/sarich/fix-tao-pounders-repeating
>   origin/sarich/tao-add-fortran-stubs
>   origin/sarich/tao-get-number-ksp-its
>   origin/sarich/tao-history-store-ksp-its
>   origin/shri/ts-dae-semi-explicit
>   origin/shri/ts-is-for-differential-variables
>   origin/shri/ts-powergrid
>   origin/stefano_zampini/pcbddc-changeofbasis
>   origin/stefano_zampini/pcbddc_deluxe
>   origin/stefano_zampini/pcbddc-primalfixes
>   origin/tisaac/dm-dim-embed-auto
>   origin/tisaac/thplex
>   origin/tisaac/thplex-remove-ksp-loop
> [how about branches that got merged from bitbucket web interface?]
I hope that didn't happen much.  Let's give people some time to comment
on these branches.  Let's try to graduate those that can in the near
future, then reset 'next' and re-merge the left-over branches.
> I see you [or someone else] did some branch cleanup. Perhaps there are
> more branches that can be deleted on the server.
I cleaned up old branches some weeks ago.
> I see the following branches merged to v3.5 release. perhaps they can
> be deleted now?
> Thanks,
> Satish
> $ git branch -r --merged v3.5 |egrep -v origin\/\(master\|maint\|next\)
>   origin/balay/add-ISColoringValue-to-finclude
>   origin/balay/chk-optflags-in-cflags
>   origin/balay/fix-multiple-zisltogf.c
>   origin/balay/fix-win32-printf-2digit-exponent
>   origin/balay/remove_intel_fast
>   origin/barry/feature-OSX-example
>   origin/barry/feature-dmmoab-hdf5-tests
>   origin/barry/fix-istogeneral_block
>   origin/barry/fix-matlab-socket
>   origin/barry/fix-redundant-matrix
>   origin/barry/vince
>   origin/bermeo/add-mkl-pardiso
>   origin/hzhang/mat-inertia
>   origin/jed/license
>   origin/knepley/doc-fe-dualspace
>   origin/knepley/feature-problem-class
>   origin/knepley/feature-quad-fas
>   origin/knepley/fix-complex-build
>   origin/knepley/fix-fe-gpu
>   origin/sarich/fix-tao-linesearch-counter-view
>   origin/sarich/tao-purge-dm
>   origin/shri/ts-events
>   origin/stefano_zampini/pcbddc-maint
done
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140909/b1318a10/attachment.sig>
