[petsc-dev] unwind next branch
Tue Sep 9 18:33:48 CDT 2014
On Tue, 9 Sep 2014, Jed Brown wrote:
> Satish Balay <balay at mcs.anl.gov> writes:
> > Jed,
> > After 3.5 release we have not unwound next branch.
> > With 3.5.2 out - is it a good time to unwind?
> > This might need some coordination as there are some old branches that
> > are not yet merged to master/next.. (so they need rebase?)
> I'd rather re-merge than rebase unless there was something wrong with the original version.
> > balay at asterix /home/balay/petsc (master)
> > $ comm -12 <(git branch -r --merged next | sort) <(git branch -r --no-merged master | sort)
> >   origin/balay/fix-glibc-2.20_DEFAULT_SOURCE
> >   origin/balay/update-etags
> >   origin/balay/update-hdf5
> >   origin/jed/sr-driver4
> >   origin/jed/vecghostgetvalues
> >   origin/karpeev/fix-ksp-pcgasm
> >   origin/knepley/feature-optcontrol-mg
> >   origin/knepley/feature-plex-nasm
> >   origin/knepley/feature-quadrature-fortran
> >   origin/knepley/fix-quadrature-order
> >   origin/madams/sr-driver4
> >   origin/mlange05/fix-gmsh-coordinates
> >   origin/next
> >   origin/paulmullowney/aijcusp-ellpack-fix
> >   origin/prbrune/sf-examplefix
> >   origin/prbrune/snes-ex19vtkoutput
> >   origin/sarich/fix-tao-linesearch-reset
> >   origin/sarich/fix-tao-pounders-repeating
> >   origin/sarich/tao-add-fortran-stubs
> >   origin/sarich/tao-get-number-ksp-its
> >   origin/sarich/tao-history-store-ksp-its
> >   origin/shri/ts-dae-semi-explicit
> >   origin/shri/ts-is-for-differential-variables
> >   origin/shri/ts-powergrid
> >   origin/stefano_zampini/pcbddc-changeofbasis
> >   origin/stefano_zampini/pcbddc_deluxe
> >   origin/stefano_zampini/pcbddc-primalfixes
> >   origin/tisaac/dm-dim-embed-auto
> >   origin/tisaac/thplex
> >   origin/tisaac/thplex-remove-ksp-loop
> > [how about branches that got merged from bitbucket web interface?]
> I hope that didn't happen much.  Let's give people some time to comment
> on these branches.  Let's try to graduate those that can in the near
> future, then reset 'next' and re-merge the left-over branches.
Ok.
Also we have quiet a few development branches. Not sure if any
of them are abandoned [and should be purged..]. Perhaps we
should review these branches aswell.
Satish
$ git branch -r --no-merged origin/next  |cat
  origin/HEAD -> origin/master
  origin/adams/zeroDSOR
  origin/balay/atpesc-tutorial-2014-bgq
  origin/balay/giturl-fixes
  origin/barry/add-snespseudo
  origin/barry/august-tutorial
  origin/barry/fix-prefix-installs
  origin/barry/html
  origin/barry/make-petscoptionsobject-nonglobal
  origin/barry/new-test-makefiles
  origin/barry/newhtml
  origin/barry/saws-options
  origin/barry/superlu_mt
  origin/barry/twitter
  origin/dalcinl/dm-destroy
  origin/debo/mat-taij
  origin/debo/ts-irk
  origin/emil/fix-ts-dae
  origin/hzhang/fix-ptaptest
  origin/hzhang/ksp-fminres
  origin/hzhang/ksp-minresqlp
  origin/irving/fe-scalars
  origin/irving/snes-ex12-cleanup
  origin/jed/assembly-perf
  origin/jed/august-tutorial
  origin/jed/chem
  origin/jed/cray-externc
  origin/jed/defined-nocpp
  origin/jed/feature-dmda-section
  origin/jed/feature-sf-local
  origin/jed/ksp-plugin
  origin/jed/mat-eigenvalue-cache
  origin/jed/mat-taij
  origin/jed/next-seaice
  origin/jed/tap
  origin/jed/ts-ex11-union
  origin/jed/ts-heat-plex
  origin/jose/mumps-bugfix
  origin/karpeev/fix-pc-fieldsplit-reset
  origin/klaij/fieldsplit-simple-ex70
  origin/knepley/dmswarm
  origin/knepley/feature-da-repartition
  origin/knepley/feature-ds-fortran-example
  origin/knepley/feature-fe-fv-hybrid
  origin/knepley/fix-mem-init
  origin/knepley/pylith
  origin/knepley/solkx
  origin/knepley/sr-driver
  origin/knepley/swarm
  origin/madams/ex56params
  origin/madams/sor-residual
  origin/madams/sr-driver2
  origin/madams/sr1
  origin/maint
  origin/maint-tao-2.2
  origin/mark/dmshell-ltogmap
  origin/mark/dmshell-test
  origin/mark/fortanenums
  origin/mark/gamg-zerod
  origin/master
  origin/mlange/fix-adjacency-performance
  origin/mlange/plex-distributed-overlap
  origin/mlange/plex-redistribute
  origin/mlange/plex-vertex-partitioning
  origin/peller/threadcomm
  origin/prbrune/matcoloring-creategraph
  origin/prbrune/matcoloring-minpack
  origin/prbrune/matcoloring-misimprovement
  origin/prbrune/matcoloring-zoltan
  origin/prbrune/pcgamg-bootstrap
  origin/prbrune/pcgamg-classicalbootstrap
  origin/prbrune/pcgamg-cr
  origin/prbrune/snes-fasadditive
  origin/prbrune/zoltanupdate
  origin/psanan/ts-bz-examples
  origin/psanan/ts-multiscale
  origin/psanan/ts-rhs-partitions
  origin/psanan/ts-tests
  origin/psanan/vec-mtdot-fix
  origin/sarich/fix-tao-example-warning
  origin/sarich/rnet-all
  origin/sarich/rnet-fix-rebase
  origin/sarich/rnet-import
  origin/sarich/snesvi-subvec-options
  origin/sarich/tao-docs-update
  origin/sarich/tao-lnks
  origin/sarich/tao-separate-state-design
  origin/shri/FTRTDS-project
  origin/shri/external-package-KLU
  origin/shri/feature-dm-circuit
  origin/stefano_zampini/dmda-changeaotype
  origin/stefano_zampini/dmdagetao-memscalable
  origin/stefano_zampini/hypre-ams
  origin/tisaac/fix-gamg-set-coordinates
  origin/tisaac/petsc-next-upstream
  origin/tisaac/thplex-on-master
  origin/tisaac/warn-next-upstream
  origin/xolotl
