[petsc-dev] unwind next branch
Tue Sep 9 17:50:58 CDT 2014
Jed,
After 3.5 release we have not unwound next branch.
With 3.5.2 out - is it a good time to unwind?
This might need some coordination as there are some old branches that
are not yet merged to master/next.. (so they need rebase?)
balay at asterix /home/balay/petsc (master)
$ comm -12 <(git branch -r --merged next | sort) <(git branch -r --no-merged master | sort)
  origin/balay/fix-glibc-2.20_DEFAULT_SOURCE
  origin/balay/update-etags
  origin/balay/update-hdf5
  origin/jed/sr-driver4
  origin/jed/vecghostgetvalues
  origin/karpeev/fix-ksp-pcgasm
  origin/knepley/feature-optcontrol-mg
  origin/knepley/feature-plex-nasm
  origin/knepley/feature-quadrature-fortran
  origin/knepley/fix-quadrature-order
  origin/madams/sr-driver4
  origin/mlange05/fix-gmsh-coordinates
  origin/next
  origin/paulmullowney/aijcusp-ellpack-fix
  origin/prbrune/sf-examplefix
  origin/prbrune/snes-ex19vtkoutput
  origin/sarich/fix-tao-linesearch-reset
  origin/sarich/fix-tao-pounders-repeating
  origin/sarich/tao-add-fortran-stubs
  origin/sarich/tao-get-number-ksp-its
  origin/sarich/tao-history-store-ksp-its
  origin/shri/ts-dae-semi-explicit
  origin/shri/ts-is-for-differential-variables
  origin/shri/ts-powergrid
  origin/stefano_zampini/pcbddc-changeofbasis
  origin/stefano_zampini/pcbddc_deluxe
  origin/stefano_zampini/pcbddc-primalfixes
  origin/tisaac/dm-dim-embed-auto
  origin/tisaac/thplex
  origin/tisaac/thplex-remove-ksp-loop
[how about branches that got merged from bitbucket web interface?]
I see you [or someone else] did some branch cleanup. Perhaps there are
more branches that can be deleted on the server.
I see the following branches merged to v3.5 release. perhaps they can
be deleted now?
Satish
$ git branch -r --merged v3.5 |egrep -v origin\/\(master\|maint\|next\)
  origin/balay/add-ISColoringValue-to-finclude
  origin/balay/chk-optflags-in-cflags
  origin/balay/fix-multiple-zisltogf.c
  origin/balay/fix-win32-printf-2digit-exponent
  origin/balay/remove_intel_fast
  origin/barry/feature-OSX-example
  origin/barry/feature-dmmoab-hdf5-tests
  origin/barry/fix-istogeneral_block
  origin/barry/fix-matlab-socket
  origin/barry/fix-redundant-matrix
  origin/barry/vince
  origin/bermeo/add-mkl-pardiso
  origin/hzhang/mat-inertia
  origin/jed/license
  origin/knepley/doc-fe-dualspace
  origin/knepley/feature-problem-class
  origin/knepley/feature-quad-fas
  origin/knepley/fix-complex-build
  origin/knepley/fix-fe-gpu
  origin/sarich/fix-tao-linesearch-counter-view
  origin/sarich/tao-purge-dm
  origin/shri/ts-events
  origin/stefano_zampini/pcbddc-maint
