[petsc-dev] configuring PETSC for a cluster with GPUs
mary sweat mary.sweat78 at yahoo.it
Thu May 15 07:39:06 CDT 2014
hmmm I'm still not able to make the code work on my cluster with GPUs :(
Il Mercoledì 14 Maggio 2014 19:33, Jed Brown <jed at jedbrown.org> ha scritto:
mary sweat <mary.sweat78 at yahoo.it> writes:
> I'm trying to use Petsc to solve a system with ksp preconditioned with
> jacobi.  Is this algorithm effivient in a GPU cluster?
That algorithm runs fine on the GPU if the problem size is large enough,
but why are you using that algorithm?  (It converges very slowly for
most problems.)
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140515/9454aeab/attachment.html>
