[petsc-dev] configuring PETSC for a cluster with GPUs
Jed Brown jed at jedbrown.org
Wed May 14 12:03:03 CDT 2014
mary sweat <mary.sweat78 at yahoo.it> writes:
> I'm trying to use Petsc to solve a system with ksp preconditioned with
> jacobi.  Is this algorithm effivient in a GPU cluster?
That algorithm runs fine on the GPU if the problem size is large enough,
but why are you using that algorithm?  (It converges very slowly for
most problems.)
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140514/7c5792ff/attachment.sig>
