[petsc-dev] fortran compiler option
Wed May 14 14:26:49 CDT 2014
looks like ifort,pgf90 are truly freeform.
absoft-f90, gfortran, sunf90 are limited to 132 chars.
Satish
On Wed, 14 May 2014, Barry Smith wrote:
>   Satish,
>     gfortran defaults to 132
> -ffree-line-length-n
> Set column after which characters are ignored in typical free-form lines in the source file. The default value is 132. n may be ‘none’, meaning that the entire line is meaningful. -ffree-line-length-0 means the same thing as -ffree-line-length-none.
> Request-assigned: Satish   have ./configure check and add the argument ffree-line-length-none when setting up the Fortran compiler
>    Thanks
>     Barry
> Where it does all the other adding of various compiler options deep in BuildSystem
