[petsc-dev] fortran compiler option
Wed May 14 14:20:41 CDT 2014
  Satish,
    gfortran defaults to 132
-ffree-line-length-n
Set column after which characters are ignored in typical free-form lines in the source file. The default value is 132. n may be ‘none’, meaning that the entire line is meaningful. -ffree-line-length-0 means the same thing as -ffree-line-length-none.
Request-assigned: Satish   have ./configure check and add the argument ffree-line-length-none when setting up the Fortran compiler
   Thanks
    Barry
Where it does all the other adding of various compiler options deep in BuildSystem
