[petsc-dev] fortran compiler option
Wed May 14 15:54:49 CDT 2014
  add the gfortran flag as I requested and turn gfortran into true free-form. And check the others for options also.
   Thanks
   Barry
On May 14, 2014, at 2:26 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> looks like ifort,pgf90 are truly freeform.
> absoft-f90, gfortran, sunf90 are limited to 132 chars.
> Satish
> On Wed, 14 May 2014, Barry Smith wrote:
>>  Satish,
>>    gfortran defaults to 132
>> -ffree-line-length-n
>> Set column after which characters are ignored in typical free-form lines in the source file. The default value is 132. n may be ‘none’, meaning that the entire line is meaningful. -ffree-line-length-0 means the same thing as -ffree-line-length-none.
>> Request-assigned: Satish   have ./configure check and add the argument ffree-line-length-none when setting up the Fortran compiler
>>   Thanks
>>    Barry
>> Where it does all the other adding of various compiler options deep in BuildSystem
