[petsc-dev] SEGV using PETSc-GPU ViennaCL
Dominic Meiser dmeiser at txcorp.com
Tue Jul 29 12:09:10 CDT 2014
Can you send example code that reproduces this problem?
On 07/29/2014 10:54 AM, Lucas Ogura wrote:
> I am trying to use PETSc-dev for a while in a project at my
> university. I need to use the GPU for matrix-vector operations and the
> code that I'm working was already implemented using PETSc, obviously I
> choose the PETSc ViennaCL-GPU solution. The original code works
> perfectly, but when I use the GPU parameters, a SEGV occurs in some
> test cases.
> Valgrind says that is a problem with PetscMallocAlign at memalign but,
> some times, it says that the problem is MatGetDiagonal.
> I'm sending the configure.log because I don't know what are the cause
> of the problem (hope the problem is the configuration), and I would
> like to know if some similar problem were reported by PETSc-ViennaCL
> users and PETSc-CUDA users too.
> PS: My computer has a top AMD GPU and I'm not sure that I can find a
> NVIDIA GPU computer to test my code, so OpenCL solutions are better to
> me then CUDA.
Dominic Meiser
Tech-X Corporation
5621 Arapahoe Avenue
Boulder, CO 80303
USA
Telephone: 303-996-2036
Fax: 303-448-7756
www.txcorp.com
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140729/5b252bda/attachment.html>
